Go to Post It’s not that we don’t have the time to teach first principals; it’s more that we (FIRST) don’t need to. - Jack Jones [more]
Unread 04-02-2009, 19:48
Comatose Comatose is offline
AKA: Lead Student Programmer
FRC #0135 (Penn Robotics)
Comatose is an unknown quantity at this point
Multiple autonomous?
In Labview, is there a way to load multiple autonomous programs for different situations onto the cRIO, maybe even include it in the robot main? If this is possible, is there a way between matches that you could choose which one you want to use from a computer hookup?
Thanks, Comatose
Unread 04-02-2009, 19:55
Urban Hawk Urban Hawk is offline
Head of R&D and Head of Scouting
FRC #1886
Team Role: Scout
Rookie Year: 2007
Urban Hawk is infamous around these partsUrban Hawk is infamous around these partsUrban Hawk is infamous around these parts
Re: Multiple autonomous?
well you can always change the programming of the robot in the pit so you could have several versions of autonomous saved on computer and then reprogram it while in the pits to fit the circumstances.
FEAR THE HAWK!!!
Unread 04-02-2009, 20:16
Cjmovie's Avatar
Cjmovie Cjmovie is offline
1293 Resident Hacker
AKA: Christopher Corsi
FRC #1293 (D5 Robotics)
Cjmovie is a name known to allCjmovie is a name known to allCjmovie is a name known to allCjmovie is a name known to allCjmovie is a name known to allCjmovie is a name known to all
I'm not using labview, however:
You might want to wire some switches up to the digital input headers on the drivers station. Then you can just have control blocks that run one piece of code if switch 1 is active, another for switch 2, etc.
Just make sure when wiring the switches up you use a pull-up resistor! A forum search should enlighten you on how to do this.
Then simply set the switch before the match, and you're good to go.
D5 Robotics, Team 1293: Programmer, CAD'er, Mechanical, Electrical... I've made my rounds.
Events: 2006-2009 Palmetto Regional
Website: http://d5robotics.org/
Unread 04-02-2009, 20:42
p00rleno p00rleno is offline
Team Advisor & Former Team Leader
AKA: Andy
FRC #2590 (Nemesis)
Rookie Year: 2007
p00rleno is on a distinguished road
Could always make a sort of jumper if you have unused I/O ports, then read which one is closed to decide which autonomous code to use with a case structure. Or, just have a constant in the code and change it/redownload based on what you want to do
Unread 04-02-2009, 21:54
In Labview, is there a way to load multiple autonomous programs ...
Absolutely. In the basic framework there is the static reference to the Auto Independent. In the Advanced framework, this is in the Begin VI. The approach will be to make a VI reference to an additional VI. The one wired out and going into the Get Mode will be the one selected when the DS transitions to auto mode.
To make another VI for autonomous, open the Auto Independent VI and Save As... to a new file leaving the existing stuff alone. Drag a copy of the static VI reference (a container with a tabbed corner) and place it near the current one. Drag the new VI on top of the static VI reference node. Now you should have two static refs one pointing to each VI. You now need to have some logic to select which one is wired out. You can use a text file, a dip switch, a digital switch on the robot, etc. If you want to use the data coming from the DS, you should wire all of the VI refs into the loop and select inside of the loop.
If you want to, you can even use VI paths and have a full directory of stuff to run. The static VI ref is an easy way to make sure that the VI gets deployed to the cRIO and loaded into memory. But if you update the project build spec or use ftp, you can put as many VIs on disk as you like. Then instead of using the static VI ref, you use the VI Open node with a path to the VI on the cRIO. Now you need a way to select which one runs. Again, you likely want to put this inside the loop that calls Get Mode.
Greg McKaskle
Unread 04-02-2009, 21:49
Unsung FIRST Hero
Mike Betts Mike Betts is offline
Electrical Engineer
Rookie Year: 1995
Mike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond repute
Thanks, Comatose
Comatose,
The answer to your first question is to create a case structure and use a constant to select which case you want. Eventually, you may wish to make the selection external with switches or jumpers...
Your second question is where to put the code. I strongly suggest that you watch this video tutorial and then post with additional questions you may have.
Regards,
Mike
Mike Betts
Alumnus, Team 3518, Panthrobots, 2011
Alumnus, Team 177, Bobcat Robotics, 1995 - 2010
LRI, Connecticut Regional, 2007-2010
LRI, WPI Regional, 2009 - 2010
RI, South Florida Regional, 2012 - 2013
As easy as 355/113...
[FTC]: Multiple Programs or One Program with Multiple Auto Modes kevin51292 FIRST Tech Challenge 4 02-01-2009 20:37
Hosting multiple sites in multiple VMs EHaskins Website Design/Showcase 6 22-12-2007 01:09
multiple autonomous modes using easyc cerberus170 Programming 3 20-02-2007 15:01
Multiple programs/autonomous routines galewind Programming 12 09-01-2004 22:25
