Go to Post Chief Delphi is special. ... Self-police please. - PayneTrain [more]
Unread 04-02-2009, 20:19
Comatose Comatose is offline
AKA: Lead Student Programmer
FRC #0135 (Penn Robotics)
Comatose is an unknown quantity at this point
How can you add more rom space to the cRIO?
I don't know exactly what it's called but we don't want to increase the temporary memory on our cRIO, we want to increase the space for deployed code that stays on the cRIO. Is there something we can buy and install, possibly some instructions on how to do it too?
Thanks,
Comatose
More Info:
I found in the rules it says:
R59>
The control system is designed to allow wireless control of the ROBOTS. The Driver Station, cRIO Mobile Device Controller, speed controllers, relay modules, wireless bridge, batteries, and battery charger shall not be tampered with, modified, or adjusted in any way (tampering includes drilling, cutting, machining, gluing, rewiring, disassembling, etc.), with the following exceptions:
A.
Programmable parameters on the Driver Station may be set as appropriate.
B.
User programmable code in the Mobile Device Controller may be customized.
C.
Dip switches on the Mobile Device Controller may be set.
D.
Speed controllers may be calibrated as described in owner's manuals.
E.
The supplied fans attached to the Victor speed controllers may be powered from the Victor power input terminals.
F.
The fuse on the Spike relays may be replaced with a 20 Amp Snap-Action circuit breaker.
G.
The alligator clips on the battery charger leads may be replaced with Anderson Power Pole connectors (note: this is a recommended modification).
H.
Wires, cables, and signal lines may be connected via the standard connection points provided on the devices.
I.
Appropriate fasteners may be used to attach the device to the OPERATOR CONSOLE or ROBOT."?]
Does any of this stop you from adding additional space to the cRIO?
Unread 04-02-2009, 20:28
EricH's Avatar
EricH EricH is offline
New year, new team
FRC #1197 (Torbots)
Re: How can you add more rom space to the cRIO?
Yes, the first part does. You can't modify the cRIO.
However, I do believe that custom circuits are allowed, provided that they are "slaves" of the cRIO; i.e., don't control anything directly. You also must conform to <R66> and <R67>.
Past teams:
2003-2007: FRC0330 BeachBots
2008: FRC1135 Shmoebotics
Unread 04-02-2009, 20:47
crake crake is offline
National Instruments
AKA: Chris Rake
no team (Athena)
crake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond reputecrake has a reputation beyond repute
There is no method for expanding the 128MB SSD that is included on the controller, nor the 64MB of RAM. There is external SD storage, but it isn't supported in this year's kit. Just out of curiosity, why are you asking?
Unread 04-02-2009, 21:57
Unsung FIRST Hero
Mike Betts Mike Betts is offline
Electrical Engineer
Rookie Year: 1995
Mike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond repute
Thanks,
Comatose
Comatose,
The advise that Eric and Chris gave is correct. However, in my wildest imaginations I can not conceive of a reason for any team to have to do so.
To echo Chris' comment, what are you trying to do? Or rather, what makes you think that you need more memory?
Regards,
Mike
Mike Betts
Alumnus, Team 3518, Panthrobots, 2011
Alumnus, Team 177, Bobcat Robotics, 1995 - 2010
LRI, Connecticut Regional, 2007-2010
LRI, WPI Regional, 2009 - 2010
RI, South Florida Regional, 2012 - 2013
As easy as 355/113...
Unread 05-02-2009, 17:19
RyanCahoon's Avatar
RyanCahoon RyanCahoon is offline
Disassembling my prior presumptions
FRC #0766 (M-A Bears)
Rookie Year: 2007
RyanCahoon has a reputation beyond reputeRyanCahoon has a reputation beyond reputeRyanCahoon has a reputation beyond reputeRyanCahoon has a reputation beyond reputeRyanCahoon has a reputation beyond reputeRyanCahoon has a reputation beyond reputeRyanCahoon has a reputation beyond reputeRyanCahoon has a reputation beyond reputeRyanCahoon has a reputation beyond reputeRyanCahoon has a reputation beyond reputeRyanCahoon has a reputation beyond repute
(Speaking from a LabVIEW perspective, can't say for WindRiver)
I'm not sure if this has anything to do with why [Comatose] is asking, but one thing I have noticed is that if you load several different programs to the cRIO, it will just keep on downloading VIs without removing them, and so if you get enough programs built up, it can use up space fairly fast. Re-imaging the cRIO should solve this; alternatively, I've FTP'd into the cRIO and cleared out obsolete VIs that way.
Hope this helps.
--Ryan
FRC 2046, 2007-2008, Student member
FRC 1708, 2009-2012, College mentor; 2013-2014, Mentor
FRC 766, 2015-, Mentor
Unread 05-02-2009, 19:10
Originally Posted by crake View Post
Just out curiosity, why are asking?
Sorry for not replying sooner but my computer’s Ethernet said its last words a bit ago.
Nevertheless, I was trying to increase the size because we are at 20% memory, and I also had no idea that VI's sent over were still stored, so I'm going to clear them out of it.
Thanks for your help and time guys,
Comatose
Unread 05-02-2009, 20:33
AKA: Chris Rake
no team (Athena)
Fixed
Unread 05-02-2009, 21:06
Just out of curiosity, why are asking?
Unread 05-02-2009, 21:16
AKA: Chris Rake
no team (Athena)
Obviously my lesson in efficient typing has not gone well.... I have friends who dropped verbs in their note taking. Others dropped vowels. Personally I just type fast and hope all the words come out ok
can u add a new member to the top 10 kids if you take one out? Miller VEX 2 16-11-2006 10:10
Can you add something to the spell checker? devicenull CD Forum Support 79 07-11-2006 10:35
How many extra batteries should you bring, and where can you buy more? haverfordfords Electrical 6 08-02-2005 22:01
how can you get more materials? Ydnar 3D Animation and Competition 5 01-04-2002 22:04
