pic: Rosie Robotics first time doing Swerve
Re: pic: Rosie Robotics first time doing Swerve
You could have at least used vex encoders for the traction control !
Looks good, if you need any help with programming let me know. :-) |
Yikes!
Do you really need that much torque? 4 CIMs with a big reduction? |
Those look like the standard Tuff Box© Gears to me? Thats just a guess though. Last edited by Jetweb : 04-02-2009 at 23:30. |
The output and drive sprockets look like a 1:1 ratio; the cluster's appear to be a 12:1 reduction just from the looks of it. So yeah, basically tough boxes.
Ya its toughbox with optional ratio to give us a 8.5:1
Wow that seems like over kill when you have very low traction. We tested our robot and found that power has nothing to do with this game, even in a pushing match.
Looks good though |
The control of the power, how it is managed and delivered to the wheel is the key. Whether you manage it through software or through multispeed gearboxes, the team that manages it most effectively will have a big advantage. |
Dana and Rosie,
Looks nice, that ring at the bottom really helps but needs to be a good bearing surface. Have fun! |
#10
The pods will be nested into a matching "ring" of delrin.
#11
those look excellent, what i was trying to get my team to build but it isnt currently working.
Gearing them down does give you an advantage, because you will never reach a top speed of a high speed gearbox why do you need it? a slower one makes for higher torque at lower speeds, usually it is a trade off torque for speed, but if you can never get enough acceleration to go full speed trading off for speed is useless. You may not need the torque either but if it ever came down to it the torque would be needed before the speed. |
#12
Those look very well-made, although the seem very large for the components they contain. I would have moved the gears inboard and tried to get things in a bit closer. That's what we did on 114 in 2005. Swerve modules tend to take up alot of weight and volume, so the smaller, the better.
Excellent work by any means. |
| pic: Swerve protoype finished just on time | Aren_Hill | Extra Discussion | 9 | 18-03-2007 14:13 |
| pic: My first Lego Swerve Drive | Ken Leung | Extra Discussion | 5 | 16-08-2006 23:56 |
| First Time Here & Vex Robotics Kit | jeffmorris | General Forum | 11 | 11-09-2005 20:38 |
| Rosie Robotics hosts ASME meeting at Agawam HS | Rosiebotboss | General Forum | 0 | 09-02-2005 14:05 |
| Rosie Robotics off season project (w/MIT) | Rosiebotboss | General Forum | 0 | 10-11-2004 22:59 |
