Go to Post FIRST teams do not allow other FIRST teams to fail. - [more]
Unread 04-02-2009, 22:52
Ice Berg's Avatar
Ice Berg Ice Berg is offline
Seth Berg
AKA: Seth Berg
FRC #0694 (Stuy Pulse)
Rookie Year: 2007
Ice Berg is a splendid one to beholdIce Berg is a splendid one to beholdIce Berg is a splendid one to beholdIce Berg is a splendid one to beholdIce Berg is a splendid one to beholdIce Berg is a splendid one to beholdIce Berg is a splendid one to beholdIce Berg is a splendid one to behold
Send a message via AIM to Ice Berg
Bane Bots P-80 PROBLEM
So today we were running two of the old p-80 banebots gearboxes (similar to those from the 2007 KOP but with a hardened carrier plate) and they sounded a little off. We measured the current and they were pulling around 13 amps under only the load from the gearbox. We tested a CIM with no gearbox and it only pulled around 3. We fiddled with them and it seems that the end of the CIM/pinion gear is sticking too far into the gearbox. We then ran similar tests on one of the new P-80s (same reduction) and had a similar problem. We've made no modifications to these gearboxes, and it seems like more than a coincidence that this is happening on 2 of the old ones and 1 of the new ones. Have any other teams experienced this problem? We may be missing something very obvious, but I would suggest that teams using similar gearboxes test the current and see what they find. We are currently machining plates to raise out the spacer/CIM mount and believe that should fix the problem. That should be done by tomorrow so I will get back with the results then.
Mens et Manus
Unread 05-02-2009, 08:05
AJ R's Avatar
AJ R AJ R is offline
RoboGeek
FRC #1714 (More Robotics)
AJ R is a splendid one to beholdAJ R is a splendid one to beholdAJ R is a splendid one to beholdAJ R is a splendid one to beholdAJ R is a splendid one to beholdAJ R is a splendid one to beholdAJ R is a splendid one to behold
Re: Bane Bots P-80 PROBLEM
We had a similar problem when we used the Dewalt gear boxes. We just ground down the shaft and gear a little so it clears.
AJ
If you loose the match and the robot doesn't come back broken, you didn't drive hard enough.
12 to 1 Bane Bots Planetary Transmission 5n1p3r Motors 5 26-01-2009 21:47
DISCONTINUED: Bane Bots RS-550 Planetary Gearmotors Ice Berg General Forum 11 08-01-2009 09:43
pic: Bane Bots Gearbox CAD roboticWanderor Extra Discussion 12 02-12-2008 01:47
Last Years Bane Bots Gear Supports CollmandosGrl General Forum 1 27-01-2008 14:54
Bane Bots transmission sieze Demothesis Motors 3 31-03-2007 21:55
