Go to Post If you think life is fair, you are sadly mistaken. - R.C. [more]
Unread 05-02-2009, 14:08
dipmeinaluminum's Avatar
dipmeinaluminum dipmeinaluminum is offline
Michael Vilarelle Mentor
AKA: (Former Mentor 354 Westinghouse Pirates)
FRC #0333 (The Megalodons)
Rookie Year: 2000
dipmeinaluminum is a splendid one to beholddipmeinaluminum is a splendid one to beholddipmeinaluminum is a splendid one to beholddipmeinaluminum is a splendid one to beholddipmeinaluminum is a splendid one to beholddipmeinaluminum is a splendid one to beholddipmeinaluminum is a splendid one to behold
Trajectory Troubles ::LabView::
This years design consists of bringing the ball up to a shooter that is mounted on a turret. the shooter design is a one wheel shooter that is mounted to a lazy Susan powered by one motor. now i have been pulling my hair out trying to come up with some kind of program using the camera to scan and lock on to a Foe trailer. using only 200 degree of movement. ill use the Gimbol or mount it right to the shooter, i don't care. maybe using the Y servo position calculate the speed of the wheel to get the balls into the trailer. PID's and things I'm still trying to understand and use. when the trailer is far away, speed up the motor. when close, slow it down, trajectory. can any team help me out?!?! I'm dying here! i have been reading fourms and just spend all my time trying to come up with something...
Love Mike
Team#333 (2013-Present)
Team#354 (2000-2013)
https://www.youtube.com/watch?v=Bu5-NvMUQ-Y
Unread 05-02-2009, 14:24
XXShadowXX's Avatar
XXShadowXX XXShadowXX is offline
They call me Cody.
no team (None currently :\)
XXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud of
Re: Trajectory Troubles ::LabView::
this should lessen your pain
find the square root of
(dg)/(sin (2a))
gives your velocity to hit the target
d=distance
g= accleration due to gravity (32f/s^2 or 9.8 m/s^2 on earth)
sin = sine, the trig function
2a= 2 times your angle of firing
if you are always feeding a distance (in standard units), and set your angle of fire to a constant (and backward solve for the speed of the motor) you will change speed in proption to distance
Is now an engineer thanks to FIRST.
Unread 05-02-2009, 15:03
intellec7's Avatar
intellec7 intellec7 is offline
108 programmer
AKA: Gustavo
FRC #0108 (SigmaC@ts)
intellec7 is on a distinguished road
Send a message via AIM to intellec7 Send a message via MSN to intellec7
Instead of using the Tilt servo's angle as a direct input into the trajectory equation, you should use trigonometry. You know how high the target is and you know how high the camera is. tan(tilt_angle )= (height_target - height_camera)/ distance
so
distance = (height_target - height_camera) / tan(tilt_angle)
Then look into the trajectory equations for a projectile launched at constant V at an angle. It involves decomposing the angled velocity into a horizontal velocity (which never changes throughout the trajectory) and a vertical velocity (which changes due to gravity).
Radio troubles Derek Allen Control System 1 02-02-2008 16:05
Remote troubles atowle1236 General Forum 4 07-01-2008 00:11
Bandsaw Troubles John Gutmann Technical Discussion 6 13-07-2006 02:05
IR Beam Troubles Goldeye Programming 2 21-01-2006 17:15
MAX ball shot trajectory Nitroxextreme Technical Discussion 19 17-01-2006 16:47
