DS Power Source
While operating tethered, for instance at one of the "practice fields" they set up at a competition venue, what is the power source for the DS?
Perhaps I'm missing something - I rescanned the controls documents and didn't see anything, however. Is 110AC required for the DS, or can it obtain it's power from the robot, through the ethernet tether cable? I suspect the answer is yes you need 110 AC, but I wanted to find confirmation and have been unable to. This could be problematic if a team needs to run out to the field after an aborted auton round, etc to reset their robot - they likely won't have 110 AC power to hook their DS up to on the field. |
| FIRST:Source | Birdman1011395 | IT / Communications | 7 | 22-02-2006 07:17 |
| Green Light Power Source | BobC | Kit & Additional Hardware | 19 | 20-01-2006 14:44 |
| IC clock source | John Gutmann | Electrical | 4 | 14-07-2005 23:19 |
| Four Wheel, all steering, non-omniwheel, ONE power/motor source drive | FizMan | Technical Discussion | 31 | 27-04-2004 12:12 |
| Differences in Source? | Adrian Wong | CD Forum Support | 1 | 27-05-2002 20:23 |
