Go to Post Even our greatest idols make mistakes. The good ones, move on and continue to do great things. - Al Skierkiewicz [more]
Unread 05-02-2009, 17:36
Chris11246 Chris11246 is offline
FRC #1647
Chris11246 is an unknown quantity at this point
Can anyone help with encoders
Im trying to use encoders for traction control and I used to get values from the encoder but for some reason my code that worked before doesn't work and I dont think its an eletrical problem because the signal is getting to the digital sidecar and we tried with different encoders.
Does anyone have some code that they are sure works. If so can you upload it so I can test it.
Unread 05-02-2009, 18:00
Luke Pike's Avatar
Luke Pike Luke Pike is offline
Programmer
FRC #1501 (THRUST)
Luke Pike is a name known to allLuke Pike is a name known to allLuke Pike is a name known to allLuke Pike is a name known to allLuke Pike is a name known to allLuke Pike is a name known to all
Re: Can anyone help with encoders
Did you try the example program that comes with LabVIEW? Make sure you're A source and B source hooked up in the right ports.
Twitter Profile
Unread 06-02-2009, 15:28
FRC #1647
Yes the A and B signals are labled on the back of the encoder and im sure that I have them the right way on my code.
I just tried using the example program on LabView and it didnt work.
Does it matter what type of encoder I use because we cant figure it out
Need help with shaft encoders edthegeek Control System 9 23-11-2006 15:08
can anyone please tell mw where or with what can i lear programing in C techsage Programming 7 23-08-2005 00:25
Can Anyone Help????? archiver 1999 0 23-06-2002 22:58
Can Anyone With a Field Help the Rest of Us? archiver 2001 8 23-06-2002 22:43
Can anyone help me??? archiver 2001 1 23-06-2002 22:17
