crio
I still cannot connect to the crio device to update the firmware. I can ping the device. and am using the crossover directly from my computer. It doesnt show up in the remote systems of the measurement and automation explorer. I have verifyed the firewall is disabled and not using wireless. any more suggestions...
Re: crio
Re: crio
When updating firmware it is best to directly connect the cRio to your PC, and you will need a crossover cable to make this connection. To answer the original question, make sure to set you PCs Ip address to 10.0.0.6 subnet 255.0.0.0. If this is already configured correctly it should work. You should also be using the imaging tool provided by FIRST. |
Re: crio
I am using a crossover and my pc IP address is 10.0.0.6 subnet 255.0.0.0
but still cant connect using the imaging tool. Ping is good as long as I use crossover. |
Re: crio
You could try connecting a console cable to the serial port, and seeing if the cRio is booting correctly, but unless you've looked at the boot data from it before you probably won't have any luck diagnosing it. |
| CRIO Error 60 | seanl | FRC Control System | 14 | 18-01-2009 16:29 |
| cRIO v7 fails | Peter H | FRC Control System | 7 | 18-01-2009 14:26 |
| cRIO Problems | computerboi1503 | C/C++ | 7 | 11-01-2009 09:35 |
| cRIO fuse??? 20 or 30? | mynameisbob | Electrical | 12 | 09-01-2009 11:33 |
| cRIO feedback | Maxpower57 | C/C++ | 2 | 08-01-2009 19:06 |
