Go to Post And you said it would be an easy game hint... Time to break out the N-Spire and do some number crunching - CalTran [more]
Unread 05-02-2009, 18:37
s0crates s0crates is offline
s0crates is on a distinguished road
Does the PD board Output 12v Stable?
My team is using a custom circuit that doesn't have very much tolerance for voltages that aren't exactly 12v. I know the battery jumps around a lot, but once it goes through the power distribution board, is the voltage exactly 12v, or should i look into other circuits that regulate voltage to 12v. Thanks.
[FTC]: Reading the 12V Battery voltage in LabVIEW PhilBot FIRST Tech Challenge 7 12-01-2009 21:13
hybrid rules are not quite stable.. zivo123 General Forum 23 12-03-2008 00:45
Does the IR board have to go in the crate? dyanoshak Sensors 5 19-02-2008 14:56
TTL Output on CMU Board Tom Bottiglieri Programming 6 24-01-2006 18:35
Does anyone on this board work at home depot? mnkysp6353 General Forum 2 30-12-2001 13:27
