Go to Post Unfortunately, there's no special type of transmission that will magically get you past defense. The best way to deal with defense is to practice, regardless of gearing. - connor.worley [more]
Unread 05-02-2009, 18:58
Mr. E Mr. E is offline
Its physics or stamp collecting
FRC #1883
Mr. E is an unknown quantity at this point
"simple" button problem
I'm new to LabView, so this is a big problem for me, but it's probably easily solved. We are trying to wire it, so that when we press a button on a joystick, it sends the signal to a relay which in turn turns a motor forward or backward. (So, actually, it's two buttons, but I'm just trying to get one to work for now.) I attached the program I have so far, but for all I know it could be entirely wrong. Can anyone tell me how to fix what I have, or give me an example program or something? Any advise would help.
Unread 05-02-2009, 20:48
Cecil's Avatar
Cecil Cecil is offline
AKA: Alex Hummel
FRC #2010 (Lightning Bots)
Cecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to behold
Re: "simple" button problem
Here is what our team would do to set the relay. On the false side of the case, it just has it set the relay back to off. Hope this helps you out.
I'm right 90% of the time, so why worry about the other 3%?
Unread 07-02-2009, 10:56
star_lancer's Avatar
star_lancer star_lancer is offline
Programming Addict
AKA: Mike Berney
FRC #2346 (CRASH)
star_lancer is a jewel in the roughstar_lancer is a jewel in the roughstar_lancer is a jewel in the rough
Send a message via AIM to star_lancer Send a message via Yahoo to star_lancer
Hey, this is jolly good and all, but the people here at 2346 are confused what you did there, we can't get most of those items to show up in labview.
If you found anything I said helpful, please click the scales next to my post. I really appreciate those reputation points.
Team 2346 - Build, test, panic, repeat.
Unread 07-02-2009, 11:01
What items can you not find?
Greg McKaskle
Unread 07-02-2009, 13:09
rfry11's Avatar
rfry11 rfry11 is offline
Team 2791 Head Programmer
AKA: Ryan Fry
FRC #2791 (Bionic Bison)
rfry11 will become famous soon enoughrfry11 will become famous soon enough
Send a message via AIM to rfry11
I'm with 2791, and I cannot seem to find the "thing" (for lack of a better word) that you used to select the button. If i'm being vague, I've attached a button to better show what exactly I cannot seem to find.
Thanks In Advance!
2008 Pascack Pandamonium Champions. Giant thanks to teams 25 and 11!
Unread 07-02-2009, 13:34
AndrewN's Avatar
AndrewN AndrewN is offline
it's alive!
AKA: Andrew Nicholson
FRC #1778 (Chill Out)
AndrewN is just really niceAndrewN is just really niceAndrewN is just really niceAndrewN is just really niceAndrewN is just really nice
It's called "Unbundle by Name" and can be found in the third box "Cluster, Class and Variant" under 'Programming" on the functions pallet.
Andrew Nicholson
2011 FRC Robot Inspector (Seattle, Portland)
Mentor FRC 1778 "Chill Out", FTC 3018, 3940 "Hawks", 4434 "Heat Misers"
"Everything should be made as simple as possible, but no simpler."
Unread 05-02-2009, 20:53
XXShadowXX's Avatar
XXShadowXX XXShadowXX is offline
They call me Cody.
no team (None currently :\)
XXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud of
add a case structure
true input/ 1
false input/ -1
that input should give your the wanted result
i'll post again latter (my machine that runs labview can't connect to the internet)
Is now an engineer thanks to FIRST.
Unread 05-02-2009, 22:30
dmoody92 dmoody92 is offline
FRC #3015
dmoody92 is a jewel in the roughdmoody92 is a jewel in the roughdmoody92 is a jewel in the roughdmoody92 is a jewel in the rough
As other have pointed is that you are getting the value from the button but not using it to modify the functionality of the code. Wire the button output to a condition statement that will range from 1 or -1 to the motor outputs.
Different "Cam Suddenly Stops" Problem JohnC Programming 10 30-01-2007 21:37
New NEMO White Papers! "Creating a Killer Packet" and "25 Ways to Sponsor" Jessica Boucher Team Organization 0 10-08-2005 10:55
IFI Loader problem - "Invalid HEX file" wun Programming 9 22-09-2004 12:35
"Thunderbirds" Vs. "Team America" Which one will rule the box office? Elgin Clock Chit-Chat 3 07-09-2004 19:53
Potential Problem with "fighting over the goal" Kyle Fenton General Forum 4 17-02-2002 10:21
