Go to Post I do know a lot of teams need to be saved from themselves. - Karthik [more]
Unread 05-02-2009, 19:46
kay_lay's Avatar
kay_lay kay_lay is offline
AKA: Katrina Layman
FRC #2539 (Krypton Cougars)
Rookie Year: 2007
kay_lay is an unknown quantity at this point
Unhappy STUCK!! PLEASE HELP!
I have a few questionsin case you don't reply to my other team member.)
1. should I be putting my code in basic robot main?
2. If not, what should my custom .VI absolutely have and what should I wire the end loop to?
3. In general what must my program have?
Please reply soon, we are at a stand still right now. Thank you very much.
Unread 05-02-2009, 21:03
airnate airnate is offline
FRC #0236 (Techno Ticks)
airnate is a jewel in the roughairnate is a jewel in the roughairnate is a jewel in the rough
Re: STUCK!! PLEASE HELP!
1. Yes, you can put code in Basic Robot Main, although out of the box it should already give you two wheel arcade drive.
2. In a sense, you don't actually have to modify anything and you should still have a very basic drivable robot. I'm not sure what you mean by "what should I wire the end loop to?".
3. If you have more than two motors, you'll probably want to add code for the additional motors. If you have the time, you could dabble with the camera for which there is an example to track the target in autonomous mode. If you have a way to gather the balls, you may have additional motors to control to do that. There are lots of other possibilities depending on what sorts of sensors or actuators you team chooses to implement.
Unread 05-02-2009, 22:53
Jim E Jim E is offline
FRC #1523 (M.A.R.S.)
Jim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond reputeJim E has a reputation beyond repute
Are there any other FRC teams close to you? What about a manufacturer that may be use Labview or C/C+/C++ programming on a daily basis? Explore your local options. Open up to them and ask them for some help. I doubt CD can provide the in-depth programming expertise you may require.
The basic Labview code gives you arcade drive of your robot. If you do not know Labview, you need to find someone local who does. If you want your robot to do other things, like read limit switches and control more than 2 motors, you need to add code.
There are also many tutorials available to team on several websites. Search them out on CD and NI's website.
Good luck.
Team MARS = 1.523 AU from the SUN!
Jim E.
Unread 05-02-2009, 23:20
I guess we should mention that if you haven't already looked over the FRC Control System documentation, you can get it at:
http://www.usfirst.org/community/frc....aspx?id=10934
You may want to look at the Software Documentation—specifically the one entitled Getting Started with LabVIEW for FRC.
Help, our driver station is permanately stuck in enabled. eNyoron Electrical 4 27-01-2009 15:43
Help--Program Light Stuck NinJA999 Programming 7 07-02-2008 14:13
!HELP! IM STUCK IN A SUBROUTINE!!! !HELP! cdennisxlx2 Programming 21 03-11-2006 17:15
help! Am really stuck!!!! pagemauck Programming 8 29-01-2004 12:38
pic: please help us please mortals CD47-Bot Robot Showcase 5 25-01-2004 11:03
