Go to Post If it reads MINUS voltage, the power is reversed (and this is bad). - DonRotolo [more]
Unread 05-02-2009, 22:26
dmoody92 dmoody92 is offline
FRC #3015
dmoody92 is a jewel in the roughdmoody92 is a jewel in the roughdmoody92 is a jewel in the roughdmoody92 is a jewel in the rough
Autonomous Issues!
Hello. We'll the build season is winding down and I am flipping out a little bit because I am running out of time with some major things to do. It was pretty tough to go from not even knowing what lab view was a few months to make an entire robot, oh yea..also our entire programming team consists of me and another kid who has no idea what he's doing, lol! Ok, enough self pity, here's whats going on.
Today was the first day I tested out our autonomous program that I made (we are having a very simple autonomous program as we are rookies). When I run it, I get an error code saying that the PWMs are already allocated even though I only have two motors being run during this time so there should be no conflicts. Soon after I realized that in autonomous I could also trigger teleop code! Then I realized that I had PWM 1 and 3 being used in both autonomous and teleop. When I switched the teleop PWMs it worked shortly until reverting back to the same error even though I was communicating to four different PWM slots.
So the issue is the fact I seem to get a degree of crossover between teleop and autonomous which doesn't make sense to me. I can't get my code up right now but I will soon, but I wanted to post this as soon as I could because of time. Any help would be REALLY appreciated!!
Unread 06-02-2009, 00:21
nathanww nathanww is offline
Hacker
FRC #1678 (Citrus Circuits)
Rookie Year: 2007
nathanww is just really nicenathanww is just really nicenathanww is just really nicenathanww is just really nice
Re: Autonomous Issues!
I'm not exactly sure what your problem is--are you trying to declare new victors or jaguars in both your auto mode and your teleop mode? If so, it might make more sense just to do it in the constructor so that both modes can acsess the motors without conflicts.
Get yer robot source code here!
Unread 06-02-2009, 06:32
byteit101's Avatar
byteit101 byteit101 is offline
WPILib maintainer (WPI)
AKA: Patrick Plenefisch
no team (The Cat Attack (Formerly))
byteit101 is a glorious beacon of lightbyteit101 is a glorious beacon of lightbyteit101 is a glorious beacon of lightbyteit101 is a glorious beacon of lightbyteit101 is a glorious beacon of lightbyteit101 is a glorious beacon of light
yes, try this
Code:
 #include "WPILib.h"
class RobotDemo:public SimpleRobot
    RobotDrive myRobot;
    Joystick stick;
public:
    RobotDemo():
    myRobot(1,3), stick(1){}
    void Autonomous()
      myRobot.Drive(1,0);
      Wait(1);
      myRobot.Drive(0);
    void OperatorControl()
     while (IsOperatorControl(){
       myRobot.ArcadeDrive(stick);
this creates them as accessable inside all the functions in the class
Bubble Wrap: programmers rewards
Watchdog.Kill();
printf("Watchdog is Dead, Celebrate!");
How to make a self aware robot: while (∞) cout<<(sqrt(-∞)/-0);
Previously FRC 451 (The Cat Attack)
Now part of the class of 2016 at WPI & helping on WPILib
Unread 06-02-2009, 09:24
Big Kid's Avatar
Big Kid Big Kid is offline
The Coach
AKA: Nick Acosta
FRC #0816 (WesTech Anomaly)
Big Kid is a jewel in the roughBig Kid is a jewel in the roughBig Kid is a jewel in the rough
Send a message via AIM to Big Kid
if you are using labview you have to create global referances to run the motors in auto if you are opening them in the robot main.
Team 816
Student (2007-2011)
Mentor/Drive Coach (2013-)
Team 2495
Mentor (2016-)
Graduate Mech. Engineer at Lehigh University
Unread 07-02-2009, 11:02
FRC #3015
Thanks fro the responses.
I am not reinitializing new victors, I am getting error code -44037 saying that the PWMs are already allocated. I am using the global variable to share between the two modes as shown in the default code. I really need some help here if anyone might know the answer
Unread 07-02-2009, 13:34
domoarigato's Avatar
domoarigato domoarigato is offline
Team #1208 CCO
AKA: Coony
FRC #1208 (Metool Brigade)
domoarigato is an unknown quantity at this point
What are you trying to control with PWMs 1 and 3? If they're just drive motors, you should be able to control them by using a global variable and then wiring the global to the drive train.... But if you're using them for something else... I'm not too sure. Probably would have to use global variables for that too. If you are making your own globals, make sure you are changing them from write to read mode when in autonomous. (right click it and change to read mode before wiring a new global to your autonomous stuffs)
Unread 07-02-2009, 17:58
jnorris jnorris is offline
FRC #1492
jnorris is an unknown quantity at this point
We had seen this error code and it seems to be caused when you deploy from the autonomous vi window. Apparently this only downloads the autonomous VI or some how messes up the globals. After editing the autonomous vi always deploy from the MAIN PROJECT window.
Autonomous questions (Labview) and some general issues Daniel_H NI LabVIEW 15 08-01-2009 21:07
VICTOR ISSUES merybar Electrical 12 15-02-2008 18:47
Newer issues.... etdeshon Programming 4 26-01-2008 07:56
Fundraising Issues... IraJason Fundraising 32 04-09-2006 16:03
Weight Issues KathieK General Forum 1 05-11-2004 18:03
