Go to Post FIRST is not about building robots, it is about building people; the robots are just a good way to get the people there. - JamesBrown [more]
Unread 06-02-2009, 09:15
BrandonD-1528's Avatar
BrandonD-1528 BrandonD-1528 is offline
Mentor
AKA: Brandon Dusseau
FRC #1528 (Monroe Trojan Robotics)
BrandonD-1528 is a jewel in the roughBrandonD-1528 is a jewel in the roughBrandonD-1528 is a jewel in the roughBrandonD-1528 is a jewel in the rough
all most thar, plez help
All of our teams vetrens mebers graduwated last year and we have no programing mentor, were so close to geting our cood working, were down to the last 5 err0rs and eney help would be gratly apresheated.
Code:
if (leftStick.GetY() >= (1 - k))
		leftMotor.set(leftStick.GetY());
error: 'leftmotor' undeclared (first use this function)
Code:
if ((leftStick(1).GetY() < (1 - k)) && (leftStick.GetY() > k))
		if (leftStick.GetY() > leftMotor.get())
error:no mach for call to '(joystik)(int)'
Code:
if (rightStick.GetY() >= (1 - k))
		rightMotor.set(rightStick.GetY());
error: rightStick undeclared(first use this function)
error: rightMotor undeclared(first use this function)
Code:
Start_Robot_Class(RobotDemo);
error:new types may not be defined in a return type.
Brandon Dusseau (website)
Monroe Trojan Robotics mentor
Software Engineer
Michigan Tech alumnus
Unread 06-02-2009, 09:26
martin417's Avatar
martin417 martin417 is offline
Opinionated old goat
AKA: Martin Wilson
martin417 has a reputation beyond reputemartin417 has a reputation beyond reputemartin417 has a reputation beyond reputemartin417 has a reputation beyond reputemartin417 has a reputation beyond reputemartin417 has a reputation beyond reputemartin417 has a reputation beyond reputemartin417 has a reputation beyond reputemartin417 has a reputation beyond reputemartin417 has a reputation beyond reputemartin417 has a reputation beyond repute
Re: all most thar, plez help
Brandon,
I can't help with your code, but may I suggest you refrain from "cute" spelling and grammar? (I am giving you the benefit of the doubt here, that your atrocious grammar and spelling are intentional). Someone may see your post and assume that you don't care enough to put the effort of proper English into asking for help, and may be unwilling to put forth the effort to help.
(puts on flame suit in preparation for expected attacks)
Former Mentor Team 1771
Former mentor Team 4509
Unread 06-02-2009, 09:46
Racer26 Racer26 is offline
Racer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond repute
It sounds to me as though you have not declared your left and right motors
you would have to use something like:
Jaguar leftMotor*;
Jaguar rightMotor*;
This goes in the class components, at the top of the RobotDemo class
then you put:
leftMotor = new Jaguar(1);
rightMotor = new Jaguar(2);
You put this with the other declarations in the "RobotDemo" class constructor.
also, it sounds like your right joystick is also not defined. you would have to use
Joystick rightStick*;
rightStick = new Joystick(2);
in the same two places mentioned above.
Your second error is because you're calling leftStick(1).GetY(), instead of just leftStick.GetY();
Unread 06-02-2009, 09:53
Mentor
Sorry i am dyslexic the worst in the hole tristate rigon and i forgot to spell check the title and did not mean to sound "cute".
Software Engineer
Unread 06-02-2009, 10:05
Mentor
thank you we fix these errors but does any one know whats up with the last error.
Software Engineer
Unread 06-02-2009, 12:14
Its hard for us to tell without seeing the rest of your code. I recommend posting your entire CPP file, as its usually the result of some minor syntax error.
help plez team1203 4life Programming 3 10-11-2008 06:02
What is your most loved and most hated video games of all time? Elgin Clock Chit-Chat 64 25-10-2004 09:41
What is your most loved and most hated video games of all time? Elgin Clock IT / Communications 8 14-07-2004 18:31
Plez help me Wacko324 Control System 8 26-01-2004 20:24
