Go to Post We need to celebrate great things because good enough isn't inspiring. - Andrew Schreiber [more]
Go Back   Chief Delphi > Technical > National Instruments LabVIEW and Data Acquisition
Unread 06-02-2009, 18:29
Technic-R-C Technic-R-C is offline
FRC #2358
Technic-R-C is an unknown quantity at this point
Switching between Autonomous and Teleoperated
Hello,
I have a question in regards to the Driver Station and LABVIEW. How do i switch between autnonomous and teleoperated periods using labview? Do we have to use the switch on the Driver Station and some code in labview or is there a tempelate available that does it automatically??? Is there a location where this info is posted?
Oh boy, so many questions... please reply asap
Thank you
Technic-R-C
Unread 06-02-2009, 21:01
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Re: Switching between Autonomous and Teleoperated
During development and practice, you choose between Autonomous and Teleoperated by using the Driver Station switch. During competition, the Field Management System will control the mode.
The Basic Get Mode VI in the LabVIEW code provides a way to read the competition state. Feeding it into a case structure lets you do different blocks of code depending on whether the state is Autonomous or Teleoperated.
You can find this information (and a lot of other important facts) in the Using the LabVIEW FRC Framework document, which is linked to on the http://www.usfirst.org/frccontrolsystem page.
Unread 06-02-2009, 22:18
FRC #2358
Thank you, I appreciate it
Technic-R-C
Unread 07-02-2009, 08:55
Russ Beavis Russ Beavis is offline
Russ Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond repute
http://www.chiefdelphi.com/forums/sh...ight=fms+light
Of further interest, the field control experts at FIRST have released a "light" version of the field management system for teams to utilize during development and scrimmages. It's available via FIRST's website "with" all of the Control System documentation (see below).
http://www.usfirst.org/community/frc....aspx?id=10934
Russ
Switching between Hybrid and User-Controlled Zyklon Programming 3 13-02-2008 08:30
Autonomous Switching Nicole_Ypes VEX 11 17-03-2007 08:09
Switching to/from autonomous mode RDD Programming 6 12-02-2007 16:14
Autonomous and user controlled mode switching sparrowkc Electrical 3 15-01-2007 13:15
Question about switching autonomous modes DemonYawgmoth Programming 2 23-03-2005 17:02
