Autonomous and Teleoperated
Hello
I have a question in regards to switching between teleoperated and autonomous modes of the code. In other words how exactly does teleoperated/autonomous period work? Will there be a template that all of the teams will have to use in order to switch between the two periods or maybe will the teleoperated/autonomous button be used? Is there a VI/template that can help us with this task in LABVIEW at the moment? So many question... if possible please respond asap Thank you Technic-R-C |
Re: Autonomous and Teleoperated
the competition port will alow the feild controller to set the bots into auto or teleop.
i'm not a coder though, so i can't help more than saying that the switch is controlled by the feild competition port. -Z |
Got it, Thank you. However, does anyone know how the field controller will distinguish the autnomous code vs. the teleoperated code?
Technic-R-C |
for our team its just a flip of the switch. but idk about the programming for it
With the release of FMS Light, you can use it to shift the DS from autonomous to teleop from a remote PC. As far as differentiating the autonomous and teleop code in your MDC, I'm not sure, but the FMS light will at least let you shift between them as it will be done at the regionals.
FMS Light is on the FIRST FRC Control System page at the bottom. |
Thank you for your responses, FMS Light looks great, i'll look into that. After searching the internet and related posts I have come across my answer.
Thanks again, the help was much appreciated, Technic-R-C |
The FRC version of LabView comes with two "robot templates" - a basic one, and advanced one. Both will work with the FMS (I can't see how you could get a robot to work without either templates, but I guess its possible).
You can get to these templates by clicking on "New FRC Robot Project" from the splashscreen. Hope this helps. -Tanner |
Thank you for your response Technic-R-C |
How do you set up FMS Light with your robot after you download it? Is there a diagram for the hardware required?
| Switching between Autonomous and Teleoperated | Technic-R-C | National Instruments LabVIEW and Data Acquisition | 3 | 07-02-2009 08:55 |
| Autonomous and Teleoperated | Technic-R-C | NI LabVIEW | 2 | 06-02-2009 22:19 |
| What can the payload specialists do during teleoperated? | AlexD744 | General Forum | 2 | 03-01-2009 19:26 |
| Detecting Hybrid \ Teleoperated | king vash | Programming | 4 | 14-07-2008 13:15 |
| Keepers in Teleoperated mode | burkey_turkey | Rules/Strategy | 47 | 05-03-2007 12:56 |
