Go to Post Courtesy and kindness should be the words for the weekend. - IndySam [more]
Unread 06-02-2009, 23:05
agough's Avatar
agough agough is offline
FRC #0234 (Cyber Blue)
agough is an unknown quantity at this point
Exclamation Radio Malfunction
We have a second robot and we have changed the IP address for saftey reasons so now both robots have different IP addresses. We have just finished doing this and we ran into a problem. Our radio (on robot) will not reply a ping from the cmd nor will it download code(using WindRiver). The odd thing is if we directly cable it to the radio (robot) we recieve a reply when it is pinged. Also we recieve battery voltage and niether the radio (on controls) nor the driverstation have problems.
We have tried reseting the radio (robot) and it didn't work. The problem might relate to the WindRiver(it still uses the old IP address). Could doing a full reset and redo work?
"By failing to prepare, you are preparing to fail."-Benjamin Franklin
"Wise men talk because they have something to say; fools, because they have to say something."-Plato
Unread 07-02-2009, 00:35
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Re: Radio Malfunction
Changing the IP address has probably put it out of the subnet that the computer is configured for. If your subnet mask is 255.255.255.0, change it to 255.0.0.0 and then every address in the 10.n.n.n range should be reachable.
Unread 07-02-2009, 08:52
agough's Avatar
The subnet mask is at 255.0.0.0 and there is no change.
Arcade/Tank Drive Malfunction piedmont Programming 2 19-01-2009 17:37
HELP!!! VEX malfunction!!! ReapersRule VEX 21 14-12-2008 17:13
circuit breaker malfunction drosophyllum Electrical 5 26-02-2008 08:11
Code malfunction after robot reset? jgannon Programming 6 01-03-2006 14:42
