Go to Post We design for being on a dysfunctional alliance: all the time. - boomergeek [more]
Unread 07-02-2009, 09:23
AG-chadd's Avatar
AG-chadd AG-chadd is offline
FRC #1495
AG-chadd is on a distinguished road
Question Camera not tracking
Our camera will not track. By this I mean it will lock on to the colours but it will not follow when we move them. We are using the 3 colour track demo.
(>^_^)>
Unread 07-02-2009, 09:27
AG-chadd's Avatar
FRC #1495
Re: Camera not tracking
By 3 colour track demo I mean 2 colour track demo. Colour is not a typo.
Unread 07-02-2009, 10:13
Brdn666's Avatar
Brdn666 Brdn666 is offline
AKA: Brandon
FRC #2604 (Metal & Soul)
Brdn666 is an unknown quantity at this point
Send a message via Yahoo to Brdn666
Are you getting servo positions outputs?
Unread 07-02-2009, 10:51
One debugging technique is to grab the servo and see if you can manually move it. It a servo doesn't hold resist and hold its position, then it is not receiving a signal or power. If it is stiff, then it is a SW problem.
If it is limber, look to make sure you have jumpers next to the PWM connector. This jumper sets the voltage of the PWM being produced. Also check that your SW channels and your electrical connectors are in agreement. Also, make sure you are using the correct module number. Finally, see if your DIO sidecar has a solid or blinking LED next to the power plug. If blinking, that means that the FPGA watchdog has disabled outputs. If blinking, make sure the DS is enabled, and make sure that the SW is feeding the watchdog in a reasonable way.
If none of this is your problem, post more observations and symptoms.
Greg McKaskle
Camera moving but not tracking ijk90825 Programming 3 31-01-2009 14:40
Camera tracking but not moving penguain NI LabVIEW 9 30-01-2009 10:10
Camera Tracking not working? NinJA999 C/C++ 0 25-01-2009 15:28
Camera locked in "tracking", but not tracking geeknerd99 Programming 1 18-02-2007 22:47
camera jerks and does not lock on when tracking kirkio Programming 2 10-02-2006 23:43
