Go to Post How many of the team's current students were even alive when those awards were earned? :) - Alan Anderson [more]
Unread 07-02-2009, 17:03
Christine_Ilich's Avatar
Christine_Ilich Christine_Ilich is offline
Team Musician and Human Cannon
FRC #2910 (Jack in the Bot)
Team Role: Human Player
Christine_Ilich is an unknown quantity at this point
declaring a servo in begin.vi (advanced framework)
alright, how do you declare a servo in the advanced framework in the begin.vi? we've tried multiple ways of doing this, but none seem to work , also if there's anything else needed to make sure the servos work please tell us
Thank you
~Jack in the Bot
~A BENDY STRAW~
www.freewebs.com/jitb
www.etherpad.com/jitb2910
Unread 07-02-2009, 19:03
Luke Pike's Avatar
Luke Pike Luke Pike is offline
Programmer
FRC #1501 (THRUST)
Luke Pike is a name known to allLuke Pike is a name known to allLuke Pike is a name known to allLuke Pike is a name known to allLuke Pike is a name known to allLuke Pike is a name known to all
Re: declaring a servo in begin.vi (advanced framework)
First drag out a Servo Open vi. Right-click the PWM Channel and click "Create > Constant". Next, Right-click on the Servo Ref on the right and click "Create > Control". Switch to the Front Panel and copy the Servo Ref. Delete it and open up the RobotData typedef. Paste the control and add it to the cluster. Go back to the Begin vi and pull down on the Cluster Elements By Name. You should see your newly added Servo Ref. Wire the output of the Servo Open vi into the Cluster. Now where ever RobotData is, you can access the servo. If you want to add it to a different typedef, just do the same things, only with a different typedef.
Hope that helps!
Twitter Profile
Unread 10-02-2009, 18:41
Thank you very much. We'll try that as soon as we get our "robot" back from the machine shop.
~Jack in the Bot
~A BENDY STRAW~
Tank Drive with Advanced Framework in Labview finman NI LabVIEW 4 30-01-2009 13:35
New TipJar Training Video - Making Friends with the FRC Advanced Robot Framework LVMastery Programming 0 05-01-2009 14:54
FRC Framework Guide Jon236 FRC Control System 0 17-11-2008 18:18
Robot Framework lord Purity Pneumatics 3 21-01-2007 15:57
Servo behavior question / advanced servo/PIC programming question DanL Electrical 12 18-10-2005 18:33
