Go to Post It's not GP, its not un-GP, its just a strategy. - AndyB [more]
Unread 07-02-2009, 18:13
brianelite brianelite is offline
FRC #2898
brianelite has a spectacular aura aboutbrianelite has a spectacular aura aboutbrianelite has a spectacular aura about
Directly connect to camera
Does anyone know how to directly connect to the AXIS camera? I tried typing in 192.168.0.90 and 192.168.0.6 in IE, but that didn't work...
Unread 07-02-2009, 20:53
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Re: Directly connect to camera
192.168.0.90 is correct. But the camera has to be on the same network as the computer. You won't be able to connect to it through the cRIO.
Unread 09-02-2009, 00:47
knine143 knine143 is offline
FRC #1047
knine143 is on a distinguished road
Also, you also need to manually set the IP of the computer to 192.168.0.x, x being anything (0-255) other than 90.
Team Echoes: teamechoes.com
Robots on the site: Hexapod, Zippy autonomous robomagellan 1st place winner, FIRST robots
Cannot Connect to Axis Camera Wirelessly computerish Technical Discussion 4 11-01-2009 19:19
Can Relay Outputs Directly Drive LEDS ? (for testing) de_ Control System 7 11-04-2008 15:13
Connecting 7.2V (directly) to camera scottmso Programming 15 14-01-2006 23:13
How do i connect the camera for testing? naor52 Programming 1 12-01-2006 01:11
