Go to Post .. if everybody else is buying all the thingamabobs so they can practice shoving balls into the whatsit. Maybe what you really want is to buy thingys so you can build a practice whojidingle. Being the only whojidingle robot can be a real advantage come alliance picking time ... - ChrisH [more]
Unread 08-02-2009, 19:57
Straberrie's Avatar
Straberrie Straberrie is offline
The Plague
AKA: Rebecca
FRC #0375 (Robotic Plague)
Rookie Year: 2007
Straberrie will become famous soon enough
Digital Inputs?
Hello!
I am using C++ and I have a question about implementing Digital Inputs in the code... Is Get() the function that means "true" or no? I basically want an if statement saying if DigitalInput1 is true, then this, but I am unsure which function to use to set the condition... =(
Thank you!!!
Team 375: The Robotic Plague
Current Robot: I-Chihuahua
Last Event: Big Apple Breakaway
Unread 08-02-2009, 20:32
byteit101's Avatar
byteit101 byteit101 is offline
WPILib maintainer (WPI)
AKA: Patrick Plenefisch
no team (The Cat Attack (Formerly))
byteit101 is a glorious beacon of lightbyteit101 is a glorious beacon of lightbyteit101 is a glorious beacon of lightbyteit101 is a glorious beacon of lightbyteit101 is a glorious beacon of lightbyteit101 is a glorious beacon of light
Re: Digital Inputs?
DigitalInput DigtalInput1(1);//port1
if (DigialInput.Get())
do this
else
do that
Bubble Wrap: programmers rewards
Watchdog.Kill();
printf("Watchdog is Dead, Celebrate!");
How to make a self aware robot: while (∞) cout<<(sqrt(-∞)/-0);
Previously FRC 451 (The Cat Attack)
Now part of the class of 2016 at WPI & helping on WPILib
Unread 09-02-2009, 20:07
Straberrie's Avatar
The Plague
AKA: Rebecca
Rookie Year: 2007
Re: Digital Inputs?
Thank you!!!!!!
Unread 14-02-2009, 23:27
programMORT11
Posts: n/a
Re: Digital Inputs?
how would you do this in C without adding the C++ digitalinput objects? could you cast the UINT32 GetDigitalInput() function results to boolean?
Unread 15-02-2009, 01:47
Redneck's Avatar
Redneck Redneck is offline
Hacker Hick
AKA: Jamie (2.0) Moran
FRC #0599 (Robodox)
Redneck is just really niceRedneck is just really niceRedneck is just really niceRedneck is just really nice
Send a message via AIM to Redneck
Re: Digital Inputs?
I don't believe so, because C doesn't have a bool data type. Traditionally boolean logic is done in C with integers with 0 for false and 1 for true. It'll still work the same way. If you have
Code:
if(GetDigitalInput()){
    // something
it'll work the same way as the C++ bool value.
Which badges can you claim?
Using Interrupts on Digital Inputs Analog C/C++ 6 03-02-2009 23:05
Digital Inputs KRibordy C/C++ 5 25-01-2009 00:35
reading multiple digital inputs angelkat Programming 2 25-01-2009 00:22
Digital inputs, bandwith, errors? Micah Brodsky Programming 7 20-01-2003 16:08
Analog vs Digital inputs? f22flyboy Programming 8 08-11-2002 22:18
