Go to Post I don't think [Amanda] will have any trouble with Needel or the Kelsos but... I can understand Grady and we do have visible evidence of the menace that is Jessica Boucher. (just ask Billfred) - Al Skierkiewicz [more]
Thread Tools Rating: Thread Rating: 7 votes, 5.00 average. Display Modes
Unread 09-02-2009, 07:02
LVMastery LVMastery is offline
LabVIEW Educator and Mentor
AKA: Ben Zimmer
FRC #0843 (Wildcats)
LVMastery has much to be proud ofLVMastery has much to be proud ofLVMastery has much to be proud ofLVMastery has much to be proud ofLVMastery has much to be proud ofLVMastery has much to be proud ofLVMastery has much to be proud ofLVMastery has much to be proud of
Lightbulb Cruch Time Help! 3 LabVIEW Tutorial Videos: State Machines; Faster Code; Simulation
Hello All,
Well, we're down to the last week, and I've been talking to lots of teams. I know many are in great shape, and many are just getting started on their programming.
So, I wanted to squeeze in as much help as I could, as quickly as possible.
Check out the following 3 videos:
1. State Machines: Writing Flexible, Modular Code. Lifter Mechanism Example (http://www.lvmastery.com/TipJar2009-02-08_1)
In this blog entry, I discuss how to use a state machine within LabVIEW to write flexible, modular code. In this example I code and explain the state machine for a mechanical lifting system. much like what many FRC teams may use.
I discuss:
- What state machines are
- How to draw and interpret a basic state diagram
- Creating typedefs for state machine data
- Creating enums to store the actual state
- Storing all sensor inputs and machine outputs in the state machine data for use in debugging and/or the dashboard program
- How to write the state machine code using the case structure, including how to speed up development by duplicating similar cases
2. TipJar #14 - Speeding Up Slow Tele-Op Code and How Parallel Loops Can Communicate (http://www.lvmastery.com/TipJar2009-02-08_2)
In this blog entry, I discuss how to speed up time-critical code by pulling it out of the Tele-Op.vi, while maintaining the ability to share data.
I discuss:
- The fact that there is a lot of stuff going on in TeleOp, and the main loop: can take up to 200ms to run, potentially causing robot damage if limit switches are missed
- How to move the state machine created in TipJar #13 into its own deterministic, accurate, fast loop
- How moving the state machine out of TeleOp causes the debugging dashboard to fail because the state data is no longer available
- How to create a global variable to share the state machine data with the main loop for debugging
- Race conditions: why you should never write to global variables from more than one VI
- How to send info from TeleOp to the parallel loops in an easy, scalable way using a "Command Signal" global
- How using a single command signal can help ensure your important code runs perfectly in TeleOp AND autonomous modes
3. TipJar #15 - Simulating and Testing: How to put your FRC code through its paces on YOUR computer. (http://www.lvmastery.com/TipJar2009-02-08_3)
In this blog entry, I discuss how to simulate your state machine code. The real benefit here is the opportunity to test your logic on your development PC, without needing a functioning robot.
I discuss:
- How to simply modify the previous state machine example for simulation
- How to use a global "Simulate" boolean variable to selectively replace all Hardware inputs and outputs with front panel controls and indicators
- Using case structures to "case out" WPI library calls
- How to watch and debug using execution highlighting, watching the global variables and the front panel
- How you must be sure to simulate all sensors, which includes things like turning off simulated limit switches when the system "moves" away from them
- How to simulate the manual override mode by writing to the "Command Signal" global just like the TeleOp or Autonomous VIs would
Ben Zimmer
Enable Education
www.EnableEducation.com
www.FRCMastery.com
email: ben@enabletc.com
Phone/Fax: (905) 864-1858
Toll Free: (877) 872-4619
Good online tutorial explaining the Gravity simulation in Solidworks? Elgin Clock SolidWorks 7 24-06-2009 22:05
LabVIEW Video Tutorial - Debugging Your FRC Code LVMastery NI LabVIEW 0 26-01-2009 09:28
help me in LabView code mahmosh National Instruments LabVIEW and Data Acquisition 3 11-01-2009 00:18
State Based Machines in LabView Greg Marra General Forum 0 11-11-2008 11:07
State Machines doyler Programming 7 11-01-2005 00:53
