Go to Post "there are two types of underprivileged teams; the ones who whine about being underprivileged and the ones that work to become privileged". - Undertones [more]
Unread 09-02-2009, 10:27
Guopeter Guopeter is offline
AKA: Pie
FRC #0296 (Northern Knights)
Guopeter is just really niceGuopeter is just really niceGuopeter is just really niceGuopeter is just really nice
how to graph joystick inputs as a function of time?
hey teams,
I'm having difficulties graphing the joystick value to an XY graph. All I'm able to do is to plot a point (Y) and move it around as time (X) changes; how do you create a trail with that point?
Thanks!
Unread 09-02-2009, 11:59
brianrumburg's Avatar
brianrumburg brianrumburg is offline
AKA: Brian Rumburg
FRC #2352 (Metal Mayhem)
Rookie Year: 2007
brianrumburg is an unknown quantity at this point
Re: how to graph joystick inputs as a function of time?
I was able to achieve this using the Express XY Graph VI. When you drop it in your code, you will see an XY Graph VI and another VI called Build XY Graph. Go into the properties for the Build XY Graph VI and uncheck 'Clear data on each call'. This should make your point leave a trail.
I've posted a working example in another thread:
http://www.chiefdelphi.com/forums/sh...ad.php?t=73971
I hope this is what you're looking for!
-Brian
Unread 09-02-2009, 17:49
AKA: Brian Rumburg
Rookie Year: 2007
You might also look at the Waveform Chart VI. It plots a value over time (leaving trails) out of the box.
I've attached a quick example. Good luck!
-Brian
Loop time for OperatorControl function? Debug blows... Chris_Elston Programming 10 13-02-2006 14:42
Joystick Inputs Jatheon4316 Programming 12 06-02-2005 17:25
How do the Analog Inputs work? JBotAlan Electrical 3 07-01-2005 00:11
Haas CNC Mill Graph Function P-Dog Technical Discussion 9 13-03-2004 23:45
How to access other Digital inputs on OI? DougHogg Electrical 2 12-03-2003 13:57
