Go to Post Picking up tetra's is going to be as easy as picking up a person of the opposite sex. While a select few will master it; others will be bumbling maroons.. - Elgin Clock [more]
Unread 09-02-2009, 16:18
aoconnor aoconnor is offline
FRC #1779
aoconnor is an unknown quantity at this point
cRIO output files
Hello,
I was wondering if anyone had tried writing to a file on the cRIO using c++ code.
I have FTPed to the cRIO and am looking for my output file, but I don't know where in the filesystem to look.
In my main robot code I have something like...
fstream _m_file;
_m_file.open("test.txt", ios:ut );
_m_file << "1 2 3 4" << endl;
_m_file.close();
Any guesses about where "test.txt" would be put?
Thanks in advance,
Alan
GFORCE, Team #1779
Unread 09-02-2009, 16:28
3DWolf's Avatar
3DWolf 3DWolf is offline
Boots - Head Programmer / 3D
AKA: Jake
FRC #1502 (Technical Difficulties)
3DWolf is on a distinguished road
Send a message via AIM to 3DWolf Send a message via MSN to 3DWolf
Re: cRIO output files
I would assume it would put it in the root of the cRIO's memory. I'm working on a piece of code that takes and saves pictures to the cRIO's memory and from what I've read and have been told it will save it to the root unless otherwise specified.
You can call it the programming teams fault, but we'll just force your arguments nil.
There are 10 kinds of people in the world -> Those who understand binary and those who don't.
WYSIWYG - In FIRST: Greatness
Unread 09-02-2009, 17:59
wt200999's Avatar
wt200999 wt200999 is online now
Texas Instruments
AKA: Will Toth
FRC #3005 (Robochargers)
wt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud of
Send a message via MSN to wt200999
yeah just ftp to the robot. The root is the working directory so wherever you tell it to save it you will find it there.
Programming in LabVIEW? Try VI Snippets!
FIRST LEGO League 2004 - 2005
FRC Team 870 Student 2006 - 2009
FRC Team 3005 Mentor 2013 -
Problem receiving console output from cRIO Arborama Programming 7 15-02-2009 03:30
cRIO/Driver Station output to laptop smcmahon FRC Control System 3 14-12-2008 13:51
Converting step files to inventor files GMAdan Inventor 4 01-01-2007 20:09
CAD Help needed. Mech Desktop 6 files backwards to AutoCAD 14? (2d files) Elgin Clock Inventor 0 30-08-2004 23:06
Compressor output archiver 2001 1 24-06-2002 00:04
