Go to Post What happens when everything becomes fully swagged out? Also, does my robot need to have collar-popping functionality to use every feature? - AlecMataloni [more]
Unread 09-02-2009, 20:00
Dr. Manhattan Dr. Manhattan is offline
Atomic Reconstruction
AKA: Joe Bakke
FRC #2521
Dr. Manhattan is on a distinguished road
Send a message via AIM to Dr. Manhattan
A whole bunch of Solenoid issues.
I'm a rookie programmer with team 2521, I've never used LabVIEW before this season, nor been on a team until this season and am pretty much self taught. I know that I wired the solenoid and pneumatics breakout correctly.
-The pneumatics breakout is in module 8 on the cRIO.
-The solenoid wire is plugged into the breakout, white to negative, red to signal.
-The wire is plugged into the solenoid, white to negative (1), red to positive (2).
My two problems are this.
1) The solenoids are always open at default, is there any way to change this?
2) When I use the third button on the joystick plugged into USB 1, nothing happens.
Any help would be appreciated.
Edit: I included my solenoid code below.
Unread 10-02-2009, 00:33
Mark McLeod's Avatar
Just Itinerant
AKA: Hey dad...Father...MARK
FRC #0358 (Robotic Eagles)
Re: Solenoid Programming Issue.
Is this the entire test program you are running or just an example of what you have put in the Basic or Advanced Frameworks?
This needs a couple of things to run by itself:
- DS Communication
- Watchdog
You can reverse the piston tubing at the solenoid to reverse the default piston position.
Unread 10-02-2009, 17:42
AKA: Joe Bakke
FRC #2521
That's just a sample from the advanced framework, I figured I'd just post that rather than the entire thing.
Edit: What are you referring to when you say "DS Communication"?
EASY C PRO help tank drive issues!!! can any 1 solve this programming issue? mayazk Programming 2 16-02-2008 02:17
solenoid programming holty531 Programming 0 10-02-2008 16:17
Programming a Solenoid Brigander Pneumatics 4 17-02-2007 14:06
Pneumatics (Spike Relay, Solenoid etc.) Programming oceansidehs Programming 8 10-02-2007 13:58
Solenoid Programming duckshepherd Pneumatics 1 17-02-2003 09:15
