Go to Post If you want to know how to build a more competitive robot, ask. GP demands we tell you, help you, guide you, teach you. - Al Skierkiewicz [more]
Unread 09-02-2009, 21:06
dpeterson3 dpeterson3 is offline
FRC #1178 (DURT)
dpeterson3 is a jewel in the roughdpeterson3 is a jewel in the roughdpeterson3 is a jewel in the roughdpeterson3 is a jewel in the rough
Debugging issue
I am hoping some can help me with my debugging issues.
1. When I tell WR to debug, it starts sending my program and then tells me there are ubresolved symbols. All of the symbols listed are from the WPI classes I call. Default code can be sent no problem
2. When I do get code on the robot, I get a no code error on the DS. This happens in debugging mode and when I deploy. When we swith the enviroment back to Labview and another programmer deploys his vi, it works perfectly. Any ideas as to why I can not get even the default project to run?
P.S. the debugger window and kernel task window both show the program as running, but I get nothing when moving the joysticks
Issue with debugging/running code on cRio 114Klaatu0x72 Programming 5 27-01-2009 14:02
Debugging Help Culvan Van Li Programming 2 20-02-2008 22:18
printf/debugging yogibear Programming 1 16-11-2006 20:08
Making Debugging Easier dm0ney Programming 18 10-04-2005 23:32
Dynamic Debugging Tool MarkVH Programming 5 04-02-2005 18:09
