Go to Post Happy Championship and may the odds be ever in your favor! - Jon Stratis [more]
Unread 10-02-2009, 16:54
furiousgeorge's Avatar
furiousgeorge furiousgeorge is offline
FRC #3055
furiousgeorge will become famous soon enoughfuriousgeorge will become famous soon enough
HELP!!!EMERGENCY!!!RUNNING OUT OF TIME!!!
i asked recently if someone could help me to figure out how to create a labview program for a motor to run off of the joystick trigger. but when people replied they seemed to believe that i had a slight idea that i knew what i was doing. however the reality is i have NO CLUE!!! i have basic tank style driving programed on to the robot and that's it! i don't know where to begin to start programming a button controled motor. will some one please help me! i appretiate all the help that people have given me already, but i really need something closer to step by step instructions. thankyou so much!!!
Unread 10-02-2009, 17:54
shocker4256's Avatar
shocker4256 shocker4256 is offline
AKA: Luke Pukatch
FRC #0177 (Bobcat Robotics)
Rookie Year: 2007
shocker4256 is an unknown quantity at this point
Re: HELP!!!EMERGENCY!!!RUNNING OUT OF TIME!!!
i would look at this it gives a good demonstration on how to get a button to work in labview. http://decibel.ni.com/content/docs/DOC-3321
Unread 10-02-2009, 18:19
vhcook's Avatar
vhcook vhcook is online now
Reader of Things
AKA: Victoria
FRC #1939 (Kuh-nig-its)
vhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond repute
I've read through your threads, and the way you're asking questions is not going to generally get you the kind of result you want. Please read this: How To Ask Questions the Smart Way
That said, and noting that I am not a Labview expert, I think I can walk you through this if you want me to. However, you have not given me enough information to start. Here's what I need to know:
- Are you a new programmer in general, or is it just Labview that is new for you?
- What kind of motor?
- Are you planning on using a Victor or Jaguar motor controller, or are you using a Spike Relay? (Or do you not know, and want to be told)
- What do you want the motor to do when you pull the trigger?
- What do you want the motor to do when you let go of the trigger?
- Do you want the same behavior every time, or are you trying to do something complicated?
- What have you already tried?
- Have you looked at any of the tutorials (listed here), and if so, which ones?
Unread 10-02-2009, 18:49
Russ Beavis Russ Beavis is offline
Russ Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond repute
You're from Austin? Austin, Texas? Don't they teach LabVIEW in elementary schools in Austin, Texas?
I would encourage you to start at the following website. You'll first need to go through the 5 step program to get everything installed, configured and running. THEN you need to check out the LabVIEW resources linked on that same site (under Software Documentation).
http://www.usfirst.org/community/frc....aspx?id=10934
Good Luck!
Russ
Unread 10-02-2009, 18:51
There are also some LabVIEW video tutorials at ni.com and lvmastery.com.
Russ
Unread 10-02-2009, 19:08
Onward through the fog.
I believe this team is from Austin, Minnesota.
Yup.
We'll see if we can do anything to help from down thisaway.
Jane
~ Helen Keller
(1880-1968)
Unread 10-02-2009, 19:14
GaryVoshol's Avatar
Cogito ergo arbitro
Rookie Year: 2000
Just take a roadtrip up I-35, Jane.
(since 2004)
Unread 12-02-2009, 14:05
StephBrierty StephBrierty is offline
NI Academic Program Manager
AKA: Stephanie
no team (NI)
Team Role: Marketing
StephBrierty is an unknown quantity at this point
You can also call into NI's Application Engineers to talk to an engineer for help - 1-866-511-6285 from 1-7pm!
Married to 141 Alum ('97-'00) and 461 Mentor ('00-'03)
1-866-511-6285 for
- Phone Support from Applications Engineers (1-7pm Central)
- Buying extra cRIOs
- Returning your cRIO for repair
ni.com/first
Email me
NEED HELP RUNNING MULTIPLE FUNCTIONS AT SAME TIME!! rushrtr3 Programming 1 12-02-2006 02:01
Running Out of Tetras psquared89 General Forum 28 27-04-2005 12:45
Running a motor for a set time in auton Morgoth Programming 5 11-03-2003 13:59
Joysticks...running out!!! archiver 2001 0 24-06-2002 02:37
Time is running out... archiver 2001 0 24-06-2002 00:04
