Go to Post FRC isn't for every school; it takes a lot of drive just to fundraise every year. It is a premium program that requires a premium about of effort to sustain and be successful. And man is it fun to do. - JesseK [more]
Unread 10-02-2009, 17:05
Chath Maral's Avatar
Chath Maral Chath Maral is offline
User
AKA: Chathus Marlaclusos Majere
FRC #1785 (Robocats)
Rookie Year: 2007
Chath Maral is an unknown quantity at this point
Exclamation Infrared sensor in LabView
Alright, so we got some infrared sensors to help detect things in our LabView code. Problem is... I don't see anyone using these sensors except us + we don't know how to gather data from such devices in LabView. The model is the Sharp GP2D120 IR Range Sensor. Please help, as we don't have much time to experiment!
Two things:
Cake==lie;
IF(char pit=="mosh","fun","work");
GO TEAM Robocats!!!
Unread 10-02-2009, 17:57
Luke Pike's Avatar
Luke Pike Luke Pike is offline
Programmer
FRC #1501 (THRUST)
Luke Pike is a name known to allLuke Pike is a name known to allLuke Pike is a name known to allLuke Pike is a name known to allLuke Pike is a name known to allLuke Pike is a name known to all
Re: Infrared sensor in LabView
Is is an analog sensor? If so, use the Analog Channel vi's. You'll get a voltage value instead of a distance, so you will have to scale it to your needs.
Twitter Profile
Unread 10-02-2009, 18:11
EricVanWyk EricVanWyk is offline
Rookie Year: 2000
EricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond repute
Send a message via AIM to EricVanWyk
http://www.acroname.com/robotics/parts/GP2D120_SS.pdf has the information you are looking for.
Page 4 has the wiring: Vo is the signal, VCC is the 5V input.
Pages 9 & 10 have the graph you need to interpret the resulting signal.
Let us know how it works!
360 Degree Infrared Sensor Question daviamp Sensors 9 05-02-2008 17:14
Infrared Sensor Interface Problems jln646v Sensors 7 26-01-2008 13:37
Infrared sensor...receiver emayank Electrical 3 25-02-2005 19:54
Infrared Beacon and Sensor Diagnostics Code Released Kevin Watson Programming 3 25-02-2004 17:50
Warning: Error in infrared sensor construction document Kevin Watson Electrical 1 29-01-2004 19:28
