Go to Post You know when the school health nurse advises "always wear a condom"? She doesn't actually mean "ALWAYS". ::safety:: I think Dean and Woodie have a pretty good idea of when they need safety glasses and when they don't. Jason - dtengineering [more]
Unread 10-02-2009, 17:06
channan channan is offline
FRC #0296
channan is an unknown quantity at this point
Serial port for analog sensors
Hi Folks,
I'd like to connect my analog sensors (gyro, encoders...) through a serial cable so I can un-hitch them easily in case I need to remove my electrical board.
has anyone done this before? Does anybody know if the wire gauge is OK for this, or is it against the rules (the manual doesn't seem to have anything against it).
Thanks!
Unread 10-02-2009, 17:15
Unsung FIRST Hero
Mike Betts Mike Betts is offline
Electrical Engineer
Rookie Year: 1995
Mike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond repute
Re: Serial port for analog sensors
http://forums.usfirst.org/showthread.php?t=11567
Mike Betts
Alumnus, Team 3518, Panthrobots, 2011
Alumnus, Team 177, Bobcat Robotics, 1995 - 2010
LRI, Connecticut Regional, 2007-2010
LRI, WPI Regional, 2009 - 2010
RI, South Florida Regional, 2012 - 2013
As easy as 355/113...
Unread 10-02-2009, 17:20
EricVanWyk EricVanWyk is offline
Rookie Year: 2000
EricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond repute
Send a message via AIM to EricVanWyk
As Mike said, the serial port is off-limits during FIRST sanctioned events this year.
However, using serial cables is fine (just don't plug them into the serial port).
Unread 10-02-2009, 17:35
Russ Beavis Russ Beavis is offline
Russ Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond repute
I'm assuming that you're referring to the use of a 9-pin serial cable and Dsub connectors for wiring and NOT for passing data to the cRIO via its RS232 port (which is forbidden per Mike's reply). Go ahead and use whatever intermediate connections that you wish between your sensors and the Analog Breakout adapter.
Rule R45F requires that you use 20AWG or larger wire to power the Analog Breakout (18AWG or larger if you're bussing multiple Breakouts and Sidecars to a single PD output with 20A breaker).
We (the inspectors) have never extended the need for 18AWG wire or larger (the rule for providing power to all 20A circuits) beyond the "breakout" to which sensors are attached. We've always allowed these devices to use smaller wire (eg the standard PWM cables) unless they are powered directly via a 20A breaker. For example, if you use a custom circuit to power and connect sensors, you need to use 18AWG or larger power wire to the circuit but can then use smaller wire to attach devices to the custom circuit.
The Analog Breakout cannot supply more than a few amps from its onboard 5V power supply. You should be fine using 24AWG wire or larger with your sensors. I wouldn't recommend going much smaller than that (too fragile IMHO) but there is nothing in the rules that prohibits using 28AWG or smaller wire for such downstream sensor connections.
Russ
Help wiring potentiometer-to-Analog port kylehager Electrical 4 17-01-2008 17:28
No Serial Port G1279 Programming 5 10-01-2008 15:15
Serial Port Help? StargateFan Programming 12 05-07-2006 14:06
TTL port to a serial port on a demo board ImmortalAres Programming 16 09-07-2005 23:44
No Serial Port Jeff Waegelin Programming 15 09-01-2003 22:29
