Go to Post Build a student a robot and it will keep him/her busy for a few days in the spring. Teach a student how to build(design, wire, program) a robot and they will stay away from home, use some really strange language and wear funny clothes the whole year long. - Al Skierkiewicz [more]
Unread 10-02-2009, 17:27
Mike Yaremko's Avatar
Mike Yaremko Mike Yaremko is offline
296 Team Captain
FRC #0296 (Northern Knights)
Team Role: Mechanical
Rookie Year: 2007
Mike Yaremko will become famous soon enoughMike Yaremko will become famous soon enough
Jaguar Flashing Light Disable Problem
We found that our jaguar motor controllers disable (flashing yellow) when certain joystick inputs are reached. When we pull the two joysticks (tank drive) in the same direction, the wheels respond accordingly. However, when we push one joystick forward and the other back, the jaguars fail and no longer respond to any joystick input.
We are using the Drive/Four Motors and the Drive/Motors VIs in LabVIEW if that is any help.
Unread 10-02-2009, 17:49
Unsung FIRST Hero
Mike Betts Mike Betts is offline
Electrical Engineer
Rookie Year: 1995
Mike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond reputeMike Betts has a reputation beyond repute
Re: Jaguar Flashing Light Disable Problem
Mike,
Of course, it is possible that you have a bug in your code. However, you might want to be sure that you have a fully charged battery. The motor load may be pulling down the battery voltage.
Mike
Mike Betts
Alumnus, Team 3518, Panthrobots, 2011
Alumnus, Team 177, Bobcat Robotics, 1995 - 2010
LRI, Connecticut Regional, 2007-2010
LRI, WPI Regional, 2009 - 2010
RI, South Florida Regional, 2012 - 2013
As easy as 355/113...
Unread 10-02-2009, 20:13
nathanww nathanww is offline
Hacker
FRC #1678 (Citrus Circuits)
Rookie Year: 2007
nathanww is just really nicenathanww is just really nicenathanww is just really nicenathanww is just really nice
An under-voltage problem seems unlikely--in our experience, the Jaguars have worked successfully at very low voltages(like 9v registering on the DS) and the code for undervoltage is flashing red light anyway.
By "fail" do you mean they just don't execute the command, or that they stop responding to anything for a certain period of time?
Get yer robot source code here!
Unread 10-02-2009, 23:25
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
If you're using a four-motor drive system, you might have two of them swapped so they're fighting each other during an attempted turn. This could perhaps end up pulling the battery voltage low enough to disable the PWM outputs but still not trip the Jaguars' own low-voltage detection. Try taking out all of the drive motors' circuit breakers and put them back in one at a time to verify that each motor does what you expect it to.
Unread 11-02-2009, 14:55
296 Team Captain
Rookie Year: 2007
we found the problem we didnt have power going to the sidecar. Now everything works. Thanks for all the help
Jaguar yellow blinking light after updates Team 691 Electrical 8 26-01-2009 00:14
Jaguar Problem Sauce Electrical 7 10-01-2009 14:28
Jaguar and Victor Flashing lights? programmr FRC Control System 24 17-12-2008 15:44
Disable Encoders Problem mftaberner Programming 10 09-02-2007 23:26
Flashing Battery Light Max Brin Technical Discussion 3 12-01-2006 11:46
