Go to Post Minus the one time when our Autonomous mode actually reversed, ran into the robot behind us, and lodged them into the rear wall - MysterE [more]
Unread 10-02-2009, 18:32
Chath Maral's Avatar
Chath Maral Chath Maral is offline
User
AKA: Chathus Marlaclusos Majere
FRC #1785 (Robocats)
Rookie Year: 2007
Chath Maral is an unknown quantity at this point
Exclamation Vision Assistant Image Aquisition help...
Starting to think that I use Chief Delphi too much!
Well, this time it's the vision assistant. The Axis camera is directly hooked into the back, and seeing well. But, the Vision assistant will not use the 'Sequence Aquisition' command without all of the screens turning black.
I used the test image, and the command worked. This has been going on since Saturday.
Two things:
Cake==lie;
IF(char pit=="mosh","fun","work");
GO TEAM Robocats!!!
Vision Assistant help? Sykan NI LabVIEW 3 23-01-2009 06:49
Vision Assistant Sykan NI LabVIEW 1 17-01-2009 16:43
Vision assistant activation help Chath Maral NI LabVIEW 2 15-01-2009 23:14
Problem with vision assistant sagivlev NI LabVIEW 4 11-01-2009 21:48
Assistance in Vision Assistant Carmelulu` NI LabVIEW 1 10-01-2009 15:36
