Go to Post Maybe we should put one of those advisory signs: "Don't try this at home ... or at Robotics competitions" - Franchesca [more]
Unread 10-02-2009, 19:13
GillSt.Bernards's Avatar
GillSt.Bernards GillSt.Bernards is offline
AKA: Amanda Cullen
FRC #2458 (Team Chaos)
Team Role: Leadership
GillSt.Bernards is a name known to allGillSt.Bernards is a name known to allGillSt.Bernards is a name known to allGillSt.Bernards is a name known to allGillSt.Bernards is a name known to allGillSt.Bernards is a name known to all
Send a message via AIM to GillSt.Bernards
Driver's Station
We can not get the driver's station team number set up. We need help.
"A Dream is just a dream, a goal is a plan with a deadline" - Fortune Cookie-
"Life is a runaway train you can't wait to jump on"
-Sugarland (Already Gone)-
Unread 10-02-2009, 19:33
Liz Smith's Avatar
Liz Smith Liz Smith is offline
believes in robots
AKA: Pika1579
FRC #3940
Liz Smith has a reputation beyond reputeLiz Smith has a reputation beyond reputeLiz Smith has a reputation beyond reputeLiz Smith has a reputation beyond reputeLiz Smith has a reputation beyond reputeLiz Smith has a reputation beyond reputeLiz Smith has a reputation beyond reputeLiz Smith has a reputation beyond reputeLiz Smith has a reputation beyond reputeLiz Smith has a reputation beyond reputeLiz Smith has a reputation beyond repute
Send a message via AIM to Liz Smith
Re: Driver's Station
http://www.usfirst.org/uploadedFiles...s-Rev-0-5a.pdf
That is from the control system documentation. The relevant information is:
3.1.5.1 Setting Team ID
The team number is stored on the driver station and is used to generate the IP addresses for the
Driver Station and the Robot. In order to set or change the Team ID on the Driver Station the
following sequence is used:
1. Hold the DOWN button (center button under the LCD Display) wait for over 5 seconds until
the LCD Display changes. It should read “SET TEAM NUMBER” with the current number
displayed.
2. Use the UP button (leftmost) to increment the current highlighted digit to desired number.
Holding this button will continue to increment up to the number Nine and then it rolls over
back to Zero. There is no going back only counting up.
3. To move to the next digit for setting, hold the Down button until the desired digit is
highlighted. Note: It is not necessary to re-set every digit if they are currently correct. In the
case of a single digit team, only the rightmost digit must be set.
4. To cause the new Team ID to be stored, push and hold the SELECT button (rightmost) until
the LCD screen changes and indicates updating. Note: The Driver Station will reboot after
this point.
Alumna of 555 Mentor of 3940
Volunteering since 2004: Say hi to me at events!
Applications Engineer
AndyMark, Inc.
Unread 10-02-2009, 19:39
AKA: Amanda Cullen
We already tried that and we've been holding down the down button for a minute! We don't know what's goin' on!
Unread 10-02-2009, 23:12
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
What firmware version is running in your Driver Station? If you see "OTB" at the bottom of the screen, you still have the "Out of The Box" firmware, which does not support changing the team number. You'll have to update the firmware first.
If this is the case, http://www.usfirst.org/frccontrolsystem Software Updates has the directions and the .bin file you need.
Driver's station - Consistency in construction Duncan Macdonald Technical Discussion 3 10-12-2008 17:14
Inside the driver's station Jeff Rodriguez Championship Event 7 01-05-2008 22:04
Need input on driver's station problem! Hawkins Control System 9 03-04-2008 10:48
2003 IRI: A driver's last hurrah or a new rookie driver's experience? Amanda Morrison Off-Season Events 14 23-05-2003 17:39
Driver's Controls 157#1Driver General Forum 22 23-04-2002 17:06
