Optimising the camera
Apologies if this has already been asked, but any help would be greatly appreciated.
I was searching the forums but didn't see quite what I was looking for. Our team is using Windriver. We got the camera to work (using the Two color tracker). Well, I guess there are two parts to the question. Firstly, how do I see how many fps I'm getting, the CPU usage, etc? Is it possible and how? Secondly, are there any teams that have made optimisations with the camera and are willing to share code? I just need to be able to track two colors. Thanks very much! |
Re: Optimising the camera
at the top: create a new timer Timer tmr = new Timer(); just before the loop in auto or where ever your code is: int timesrun=0; tmr->Start(); in the loop: timesrun++; if (tmr->Get() >= 1.0) { tmr->Stop(); printf("This cycle was at %i Hz\n", (timesrun/tmr->Get()); tmr->Reset(); timesrun=0; tmr->Start(); } then open the console and every second, it should tell you the speed of the loop |
Awesome, thanks for the code.
How have most people been optimising the camera code? I haven't found any good camera documentation based on C++. Any help would be appreciated on this, I kinda just need some documentation. Thanks |
| error when build the project for the camera tracking | mahmosh | C/C++ | 1 | 04-02-2009 14:47 |
| Tell the difference: 2007 CMU Camera, 2006, 2005 camera? | Chris_Elston | Programming | 2 | 07-01-2008 13:11 |
| Where do I begin to get the robot to move using the camera? | Ianuser | Programming | 10 | 16-02-2007 17:55 |
| Where in the world is the new 2007 cmu camera docs?!?!? | xrabohrok | Programming | 13 | 08-01-2007 20:28 |
| problems mounting the camera to the 'bot with the default servo/mount set up | Redneck | Programming | 0 | 16-02-2005 20:53 |
