Go to Post We’ve been chasing perfection since 2003 in the hopes of catching excellence. - Karthik [more]
Unread 11-02-2009, 00:27
sbrumund sbrumund is offline
FRC #2115 (M cubed)
sbrumund is an unknown quantity at this point
Coupler for 8mm CMI motor
Does anyone make a coupler that will go from the 8mm shaft of the CMI motor to a standard 0.50 shaft with keyways?
We want to drive our ball thrower directly off of the CMI motor but cannot find a coupler to go from the 8mm motor shaft to the 0.50 wheel hub.
Unread 11-02-2009, 00:31
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: Coupler for 8mm CMI motor
did you look at the replies to your previous thread?
http://www.chiefdelphi.com/forums/sh...ad.php?t=74058
also it would help if you told us if you want to connect to a 1/2" shaft, or you want to make the motor shaft into a 1/2" shaft so you can put something with a 1/2" hole over it
Unread 11-02-2009, 03:55
SpaceOsc's Avatar
SpaceOsc SpaceOsc is offline
16 Years of FIRST!
AKA: Oscar Vasquez
FRC #4501 (Humans)
Team Role: Coach
SpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant future
Send a message via AIM to SpaceOsc Send a message via Yahoo to SpaceOsc
http://andymark.biz/am-0320.html
if u want to drive another shaft directly combine that with any other of these hubs http://andymark.biz/hubs.html
2014-2017: Team 4501 Coach/Lead Mentor
2002-2011: Team 702, Mentor
2001-2002: Team 702 Captain
spare denso motor coupler AnonymousPencil Motors 2 09-02-2009 13:09
Coupler for Denso Motor nlknauss General Forum 1 05-02-2007 17:20
CIM motor shaft Coupler Epot86 Motors 13 14-01-2006 22:05
Securing Drill Motor Coupler Ralph Lambert Motors 17 08-02-2003 01:54
using set screw or dowel pin/pin to hold on drill motor coupler thinggy Travis Covington Motors 1 04-02-2002 03:02
