gyro.h help
I'm studying the gyro.h and i have a question. I'm working with ADXRS300.
In gyro.h --> // Analog Devices' ADXRS300 (sensitivity = 5.0mV/deg/sec) #ifdef ADXRS300 #define GYRO_SENSITIVITY_DEG 2000L // in units of tenths of a degree/sec/volt #define GYRO_SENSITIVITY_RAD 3490L // in units of milliradians/sec/volt #endif the value of GYRO_SENSITIVY_DEG 2000L, how do you calculate this value? i'm reading the datasheet from ADXRS300 and i haven't found it anywhere. Please help me! Thank you |
Re: gyro.h help
There are one thousand millivolts in each volt. Does that help? |
Re: gyro.h help
Sorry, i don't understand it.
5 mV/ deg/sec 5 mV = 0,005 V by other hand in gyro.c --> int Get_Gyro_Rate(void) { // Return the calculated gyro rate to the caller. return((int)((((long)gyro_rate * GYRO_SENSITIVITY * 5L) / ADC_RANGE)) * GYRO_CAL_FACTOR); } I think that 5L was the sensitivity, and then, ¿What is it? |
Re: gyro.h help
The ADXRS300 sensitivity is 5 millivolts per degree/second.
The constant in the code is in tenth-degree/second per volt. 5 millivolts per degree/second is 0.005 volts per degree/second. 0.005 volts per degree/second is 0.0005 volts per tenth-degree/second. 0.0005 volts per tenth-degree/second is 2000 tenth-degree/second per volt. Is that clear? |
Re: gyro.h help
sorry again,
what do you do to change V per tenth-deg to V per seg? i see that 2000 is the result to divide 1/0,0005 but i don't understand it. By other side, int Get_Gyro_Rate(void) { // Return the calculated gyro rate to the caller. return((int)((((long)gyro_rate * GYRO_SENSITIVITY * 5L) / ADC_RANGE)) * GYRO_CAL_FACTOR); } 5L, what is this? thank you |
Re: gyro.h help
| Gyro problem..HELP! | zivo123 | Programming | 13 | 14-04-2008 12:06 |
| ADXRS300EB gyro help | Chris Bright | Programming | 4 | 08-02-2005 17:59 |
| gyro help | kjohnson | Programming | 6 | 03-02-2005 07:56 |
| Gyro help | Matchew | Programming | 7 | 20-01-2003 10:49 |
| GYRO help | srawls | Electrical | 5 | 01-07-2002 23:10 |
