missing set_digital_output vi
Hey guys
i can't find the Set Digital Output.vi anywhere in our program. Can anyone direct me where can i download it from? it's really important we want LEDs for the driver. Thanks! |
Re: missing set_digital_output vi
![]() This it? |
It sounds like you might to want to put the LED on a driver station. If so, look in the Driver station palette on the lower row.
Greg McKaskle |
I want an LED on the driver station, and can't find the VI, it's as if it is missing...
One thing to verify is that you are using LabVIEW update 3.0a. Do you see the VI in the attached picture? |
no, i don't see it, and i am using the correct version of LabView.
That is really odd. Go to the Tools menu and switch your palettes. Perhaps the update didn't agree with the palette files. Switch it back if you want, but see if this helps to refresh the icons.
Greg McKaskle |
It might help if you posted what your driver station pallet looked like.
it looks as though what we have is the same thing posted by Joe just without the needed VI.
Is there a way to manually download it? |
#10
WPI Robotics Library -> IO -> DigitalOutput -> SetValue.vi
#11
once again, it's not there...
#12
Are you missing the entire Driver Station palette, or just the Set Digital Output.vi?
#13
Just this one
#14
It should be located at
C:\Program Files\National Instruments\LabVIEW 8.5\vi.lib\Robotics Library\WPI\DriverStation\Set Digital Output.vi I attached ours. |
#15
There we go...
Thank you very much mate =] |
| Missing Laptop | LBK Rules | Regional Competitions | 0 | 09-03-2003 11:10 |
| Missing Mr B | archiver | 2000 | 0 | 23-06-2002 23:10 |
| Missing Ninny | Carolyn Duncan | Chit-Chat | 28 | 03-08-2001 03:07 |
