Go to Post My own opinion is that any truly great student can succeed with any teacher, and any truly great teacher can succeed with any group of students. - DampRobot [more]
Unread 11-02-2009, 19:42
agough's Avatar
agough agough is offline
FRC #0234 (Cyber Blue)
agough is an unknown quantity at this point
Question Encoder Limit
Is there an encoder limit?
I ask because when we build our program with 5 encoders used throughout it builds fine and it downloads but when we start it up our program won't run and tells us:
"Cannot allocate any more ports" check Resource.cpp line 61
We found nothing in Resource.cpp that is relevant.This is function/line it tells us to check(_=Space):
UINT32 Resource::Allocate()
____for (UNIT32 i=0; i < m_size; i++
____{
__________if ( ! m_isAllocated[i])
__________{
__________m_isAllocated[i] = true;
__________return i;
__________} <-This is line 61
____}
____wpi_fatal(NoAvailablePorts);
____return 0;
If we comment out at least one encoder object creator and pointer(and it doesn't matter which one of the five we comment out) then the error doesn't show and everything else works.
"By failing to prepare, you are preparing to fail."-Benjamin Franklin
"Wise men talk because they have something to say; fools, because they have to say something."-Plato
Limit Switches popnbrown NI LabVIEW 1 10-02-2009 22:39
Screwing Encoder into Encoder Mount? Adrien Electrical 3 25-01-2009 18:14
Using a limit switch to limit motion ManicMechanic Programming 16 20-12-2007 00:54
Spending Limit? Chuck Glick General Forum 8 08-01-2006 17:54
$$ Limit? Stephen Kowski Rules/Strategy 1 08-01-2002 00:01
