Go to Post remember to keep this simple but yet complex everyone - Team#2057-Vegas [more]
Unread 11-02-2009, 19:56
dmlawrence dmlawrence is offline
MIT '14
FRC #1751 (Warriors)
dmlawrence is an unknown quantity at this point
Reentrant VIs
I wrote a traction control VI that I made reentrant. This VI is placed on the block diagram of another VI in two locations. It is my understanding that I should be able to open two front panels of the reentrant VI - specifically, one for each block diagram instance. However, I can only open a single instance of the front panel, which is not linked to EITHER of the VI instances on the block diagram. (I don't know if it matters, but the reentrant VI is located in a while loop.) How can I get to the other front panels?
thanks,
David
Unread 11-02-2009, 20:09
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
Re: Reentrant VIs
See this recent post on the NI FIRST community: http://decibel.ni.com/content/thread/2214
Unread 11-02-2009, 20:14
MIT '14
Re: Reentrant VIs
Thanks very much... that's not exactly the solution I was hoping for, but we'll make it work.
David
Unread 11-02-2009, 20:16
Re: Reentrant VIs
Yep. That feature isn't fully supported in RT. A workaround would of course be to open the VI and save two versions under two names. Make them not be reentrant and now you can debug. You then of course need to be careful if you need to make edits. Once debugged, put it back to reentrant.
Greg McKaskle
Best Practice for Posting LabView VIs? DonRotolo National Instruments LabVIEW and Data Acquisition 8 09-04-2010 22:37
Merging/Comparing LabVIEW VIs Terry Sherman NI LabVIEW 7 30-08-2009 10:30
Adding Inputs or Outputs to existsing VIs paulcd2000 NI LabVIEW 7 12-01-2009 22:39
DAQmx VIs missing Barry Lazzer LabView and Data Acquisition 2 30-01-2007 13:06
