Solving static electricity problems by grounding the frame
Has anyone given any thought to the idea of purposely inserting a (>100kΩ) resistor between the frame and ground so as to allow any static charge built up on the robot to bleed off harmlessly? I'm a little paranoid about frying a cRIO.
I honestly can't see a downside here (other than possible ineffectiveness) but then we aren't any worse off than we are now. Kris |
Re: Solving static electricity problems by grounding the frame
Shouldn't a large metal frame be enough to discharge static electricity without the resistor?
I would be more worried about the frame gathering a static charge (what with the mandatory fabric and plastic rubbing devices covering 2/3 of your robot) than the cRio's Chassis.
Whenever you have two different materials sliding against each other there is a possibility of building up a static charge.
Last year at a scrimmage several teams had problems with static discharges that required reloading their control program (plastic wheels on dry carpet). The simplest solution is to install a lightning rod. The main purpose of a lightning rod is to dissapate charge so there is no lightning strike. Usually the sharp edges of the robots frame will so this. If you are concerned several nails installed with the points up can be used as air terminals to dissapate any charge that builds up. If you know a physics teacher ask them for a demonstration with their VanDeGraff generator. This may be a safety problem but if not located appropriatly |
Alternatively (not sure if it will be legal at competitions) you can add a drag chain from the frame to the ground to prevent charge buildup.
The easiest solution would be to ground the frame to the battery negative terminal, though that is questionable based on the rules. I'm terribly surprised that it isn't REQUIRED to ground the frame to the battery, as it is done with vehicles.
no you cant ground your frame to your battery. there is a rule against this, and rightfully so. Remember ground is only ground when it really is ground (as in earth . . mostly) Ive personally measured a 3 volt potential between 2 "grounds" on the old 2006 batteries. If 2 robots were to come in to contact with each other even as little as 3 volts between their frames could be very bad.
I really hate to be a Debbie Downer on this subject. |
The battery short issue is easily solved by using fuses and circuit breakers. For a competition like this, I've been very surprised that there isn't a rule requiring inline fuses on the positive source lines of all the batteries. Otherwise, the fuses will prevent a short from causing any issue.
As for the difference in potential between two robots, it would cause no problem whatsoever, since only grounds would touch, so there wouldn't be any power loop. Think about this example: you have a car that needs a jump. What is the first step? You connect both grounds on the batteries to eachother. In a jump situation, the difference in potential is going to be much greater than 3 VDC, and yet there is never a problem. I will connect negative terminals of batteries all day, there is no danger. By disallowing the grounding of the frame, FIRST is causing an even more dangerous problem, the situation where a single positive wire contact would could give the entire frame a POSTIVE charge, which, through a human resistor, could cause extreme physical damage. There is a very good reason all cars have their bodies/frames grounded, it is for the obvious safety benefits. |
#10
Conversely, with a grounded chassis, if a positive lead touches the frame, you've created a short to negative, meaning a massive current flow, causing the battery to heat due to internal resistance. Hot material expands, and the last thing first needs is a leaking lead-acid battery, much less the fire hazard. Quote:
--Ryan |
#11
OK, time for a break here...
The static buildup most of you are experiencing is the plastic wheels moving inside a metal housing and the wheels slipping on the plastic floor. Plastic being an operative word here as it is non conducting. Therefore any of the normal methods one uses to dissipate charge have no effect since there is no path for the static to drain off other than through the humidity in the air. The robot frame is insulated from the control and electrical system for one very important reason, we want you to be able to play. If you were allowed to add fuses or any other kind of protection device, when they tripped your robot would be dead in the water. The simple act of isolating the electrical system from the frame of the robot prevents abnormal robot to robot contact from taking you out of the match. A side benefit is that the control system remains unharmed and the chance of fire is reduced. Remember that the battery is capable of over 600 amps when fuly charged for about 7000 potential watts. In addition to all of this protection, there is a 3 amp breaker built into the PD in the negative lead of the Crio power to protect the Crio from any stray shorts that may develop. (Thanks Russ and Erik) Please remember that Inspectors will be checking for electrical shorts to robot frame. Most often these come from poorly insulated sensors but this year will also come from the Crio and camera. Both of these devices must be insulated from the robot frame per R41... <R41> All wiring and electrical devices, including all control system components, shall be electrically isolated from the ROBOT frame. The ROBOT frame must not be used to carry electrical current (e.g. this is necessary due to polarity reversals that occur under certain operating conditions such as during motor direction reversals). The chassis for the cRIO Mobile Device Controller and the supplied camera have grounded enclosures. Under this rule (and for their protection), it is REQUIRED that they be electrically isolated from the ROBOT frame when installed on the ROBOT. You are probably asking yourself 'has he really seen anything like this before?' and the answer would be YES. Smoke, flame, and robots out of commission. I know that inspectors may give you pause but our job is to insure that you play as long as you want or can. We want to see you play and will do everything in our power to insure that. Last edited by Al Skierkiewicz : 12-02-2009 at 07:42. |
#12
A drag chain is a good idea.
ErichKeane - As several others have pointed out, connecting the battery's return to the chassis is a bad thing that is illegal for very good reasons. This has examined and agreed on by many EE and safety experts, including our friends at UL. I've gathered a few quips from this thread: AdamHeard - and don't forget that a grounded frame allows a single wire failure to short the battery (a single positively charged wire coming loose). RyanCahoon - Not really, it's more a convenience incentive, that way only one power wire (positive) has to be run to devices, leading to less cable runs. Al Skierkiewicz - The robot frame is insulated from the control and electrical system for one very important reason, we want you to be able to play. And I'll add a slightly less elegant one: Quote:
"One Breaker per Path" is only viable if your topology is a star. If the ground is already shorted, you are one mistake away from breaking that assumption. |
| Lunacy Wheels Static Electricity | nilesenator | Kit & Additional Hardware | 18 | 05-01-2009 23:19 |
| Math genius rejects attention after solving problems | Andy Baker | Math and Science | 14 | 24-08-2006 01:47 |
| Static Electricity | JeffO | Championship Event | 5 | 19-04-2004 11:04 |
| Stupid Question about Static Electricity | Novice100 | Electrical | 5 | 04-02-2004 05:15 |
| Static Electricity | archiver | 2001 | 12 | 24-06-2002 00:34 |
