Go to Post It is not your banners that make you nor the trophies that line your walls. It is the willingness to be brave in the face of defeat and compassionate in the winds of victory that create you. - MysterE [more]
Unread 12-02-2009, 09:12
mahmosh's Avatar
mahmosh mahmosh is offline
FRC #1946
mahmosh is an unknown quantity at this point
problem while programming 2 bottuns in windriver
hey
we are trying to do 2 buttons for the same motor if button 1 pressed move forward .. else stop ... and then if button 2 pressed move backward else stop
here is the code we are using but it doesn't work well :
in the operatorcontrol we put this:
Code:
if(leftjoystick->GetRawButton(1));
jaguar->Set(1.0);
else{
jaguar->Set(0.0);
if(leftjoystick->GetRawButton(2));
jaguar->Set(-1.0);
else{
jaguar->Set(0.0);
what is the problem with this ?? if we deleted the second part
Code:
jaguar->Set(-1.0);
else{
jaguar->Set(0.0);
everything working ok!!
please need answer
WindRiver Programming Template kyungjin C/C++ 0 24-01-2009 16:42
Potentiometer on cRIO, Programming in Windriver sircedric4 C/C++ 3 20-01-2009 06:42
WindRiver Programming dnrobotics11 C/C++ 1 19-01-2009 20:13
WindRiver Programming dnrobotics11 C/C++ 4 19-01-2009 19:43
Problem debugging code with WindRiver LinuxMercedes Programming 3 07-01-2009 11:10
