Go to Post "We used to shut the robot up in a box and send it away from home. Now we just suffocate it." - GaryVoshol [more]
Unread 12-02-2009, 17:54
tyson2010 tyson2010 is offline
FRC #1254
tyson2010 is an unknown quantity at this point
programming buttons
Hey there,
We're trying to work on programming the joystick trigger button so it would run our throwing mechanism. any help is appreciated.
Unread 12-02-2009, 21:24
Luke Pike's Avatar
Luke Pike Luke Pike is offline
Programmer
FRC #1501 (THRUST)
Luke Pike is a name known to allLuke Pike is a name known to allLuke Pike is a name known to allLuke Pike is a name known to allLuke Pike is a name known to allLuke Pike is a name known to all
Re: programming buttons
Well, not knowing what mechanism you use makes it hard to give any help. However, I can help you with the joystick. I use the Joystick Get vi. Unbundle the buttons cluster (the trigger is button one) and wire the booleans to your throwing code, most likely some case structures.
Twitter Profile
Unread 12-02-2009, 22:17
StephBrierty StephBrierty is offline
NI Academic Program Manager
AKA: Stephanie
no team (NI)
Team Role: Marketing
StephBrierty is an unknown quantity at this point
I would recommend checking out this example that demonstrates how to make joystick button imputs do a variety of things. Or you can call into NI for help, see details below!
Married to 141 Alum ('97-'00) and 461 Mentor ('00-'03)
1-866-511-6285 for
- Phone Support from Applications Engineers (1-7pm Central)
- Buying extra cRIOs
- Returning your cRIO for repair
ni.com/first
Email me
Programming 2 buttons for a relay team877 NI LabVIEW 15 18-02-2011 00:18
programming a motor to two buttons solomason519 Programming 2 28-01-2009 12:37
Help Programming Buttons LordFrz Programming 3 14-02-2008 13:55
Programming Extra Joystick Buttons Inverted Programming 2 08-02-2007 11:45
Programming motors with joystick buttons TMHStitans Programming 5 21-03-2005 21:07
