Go to Post Never quit, never give up, never say die! - Cascade [more]
Go Back   Chief Delphi > Technical > IT / Communications > Website Design/Showcase
Unread 12-02-2009, 19:18
eternalearth888's Avatar
eternalearth888 eternalearth888 is offline
Shazbots 1245 - Monarch High School
FRC #1245 (Shazbots)
Team Role: Webmaster
eternalearth888 is an unknown quantity at this point
Exclamation IE is confusing me :(((
Okay, so for some reason, on certain computers, the IE version of our home page is cluttered/messy and simply is not fitting properly. However, on other computers, the IE version of the site works perfectly.
Firefox however, works perfectly, regardless.
Is it the IE updated version, or is something with the coding? Please help!
Sincerely,
Maria Deslis
http://www.shazbots.org
Unread 12-02-2009, 21:30
JohnBoucher JohnBoucher is offline
Blue Shirt
FRC #0237
JohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond repute
Re: IE is confusing me :(((
It looks the same for me in IE, Firefox and Chrome.
I believe what you are seeing is certain browser configurations rendering the markup differently. I ran the code through a validator and found that there are many elements out of place.
http://validator.w3.org/check?uri=ht...Inline&group=0
This will cause IE to display differently.
Try and clean up the code and see how it renders.
HTH
Blue Shirt Alaska Pics here and Amsterdam pics are here!!! and Puffin Pics
Unread 13-02-2009, 13:09
TLuck234 TLuck234 is offline
AKA: Trey
FRC #0034 (The Rockets)
TLuck234 is a jewel in the roughTLuck234 is a jewel in the roughTLuck234 is a jewel in the roughTLuck234 is a jewel in the rough
Try and fix all of the errors that show up on the validation page. That can fix some problems like this. If you need any help, or don't know what these errors are for. You can PM me and I can help ya.
Team 34 Website
2009 Awards:
Lone Star Chrysler Team Spirit Award
Peachtree Best Website
Peachtree Gracious Proffessionalism Award
2008 Awards:
Peachtree Chairman's
Unread 20-02-2009, 21:36
Thank you so much you guys! It really did help when I used it! I finally figured things out thanks to that validation code! I really appreciate you guys taking the time to help.
Things are now running smoothly in all browsers.
Do you guys know what browser the web judges check the site in?
Unread 20-02-2009, 23:32
Zholl Zholl is offline
AKA: Chris Sherwood
FRC #2996 (Cougars Gone Wired)
Zholl is a splendid one to beholdZholl is a splendid one to beholdZholl is a splendid one to beholdZholl is a splendid one to beholdZholl is a splendid one to beholdZholl is a splendid one to beholdZholl is a splendid one to beholdZholl is a splendid one to behold
No idea personally. I would say that you might want to check older versions of IE for sure. It's notorious for not being standards compliant, and I had similar issues a couple months ago. Also, I noticed you're using XHTML. I talked to someone a few weeks ago who does web design professionally, and it turns out that a lot of errors W3 spits out are bogus in XHTML. Here's what I've got from him in an email:
The majority of the errors and warnings being displayed there are bogus. The validation engine is trying to parse your script section as html. Notice in the first script section of your page, there are html comment tags ( <!-- and -->) surrounding the whole script section, just inside the script tags. This will cause the html parser to ignore everything between those tags. Your second script section does not have the comments, and so the W3 parser is incorrectly trying to evaluate the validity of that section as if it were html, which it is not. Put the comment tags around that script block as it was done in the first one, and you will eliminate the bulk of the errors.
Then you can start working away at the remaining validation errors.
A few real errors I noticed are:
</img> - image tags do not have closing tags. remove the </img> tags.
id="about us" - id and name attributes cannot have spaces in them.
id=content - attributes must be enclosed in quotation marks.
<img ...> - image tags must have an alt attribute. The alt attribute specifies the text that will be displayed in place of that image on a text-only browser.
<tr></tr> - this table row has no cells. You need to put the same number of cells in every row of a table. Remember a <td colspan="3"></td> is 3 cells.
bordercolor="#..." - although this was valid in previous html specs, some attributes have been removed from the latest html specification. Others include "border" on img tags, <font> tags, and others. In these cases you should instead use CSS styles to apply those attributes. This can be done by using a style attribute like so: style="border-color: #...; border: none; font-face: Arial" and so forth.
href="http://www.nasa.gov"target="_blank" - you need to put a space between attributes.
Also, use conditional statements if you're still having trouble. Unfortunately, I'm not very good at explaining them, so perhaps someone else could do the honors, or maybe a little research is all you need.
Unread 14-03-2009, 15:56
zim2411's Avatar
zim2411 zim2411 is offline
AKA: Peter Harris
FRC #1727 (Rex 1727)
zim2411 is a jewel in the roughzim2411 is a jewel in the roughzim2411 is a jewel in the rough
I'm judging for the Chesapeake regional, and I'm mostly using Firefox on my Vista laptop. If something appears strange I'll take a look in Safari 3, IE 7, Chrome and Opera 9.5 though. I did run into one site while grading that worked perfectly on Safari 3 only, and did not work correctly on any other browser. (So 95% of Windows users could not use the site properly)
Confusing Video Bochek Technical Discussion 13 14-02-2007 13:36
Confusing Shipping date, NYC regional Denman Rules/Strategy 1 02-02-2005 11:14
Confusing Compiler Error UrsaMNet Programming 2 28-10-2004 14:32
One Confusing Math Problem Bharat Nain Math and Science 4 01-02-2004 17:21
Ahh! Program trick confusing! archiver 2001 9 24-06-2002 02:26
