Urgent Help Needed! Running Out of Time!
We are having trouble calibrating the speed of our jaguars in labview. We did the calibration steps but it did not set a limit to the speed of the motors. Someone said that they set their PWM values to .99 and -.99. How and where do you set these values? and are they constant values or maximum and minimum values for your jaguar?
Also, is setting maximum and minimum values a hardware problem or a software problem? Last edited by TheDarkDuck : 12-02-2009 at 20:44. |
| HELP!!!EMERGENCY!!!RUNNING OUT OF TIME!!! | furiousgeorge | Programming | 7 | 12-02-2009 14:05 |
| HELP-URGENT PROGRAMMING HELP NEEDED | Rohith Surampudi | Lego Mindstorm Discussion | 1 | 24-03-2006 23:05 |
| URgent Programming Help needed | rcubes85 | Programming | 4 | 15-02-2005 23:21 |
| Gear Help Needed- Urgent | psychoCHIPMUNKK | Technical Discussion | 6 | 05-02-2004 13:44 |
| Time is running out... | archiver | 2001 | 0 | 24-06-2002 00:04 |
