Go to Post It's not pink enough, I don't beleive it! :p - Lil' Lavery [more]
Unread 12-02-2009, 20:12
Dethshoot1's Avatar
Dethshoot1 Dethshoot1 is offline
AKA: Andres Avalos
FRC #0004 (Element)
Team Role: Electrical
Rookie Year: 2007
Dethshoot1 is an unknown quantity at this point
Send a message via AIM to Dethshoot1
Jaguar placement
Is there any rule against placing Jaguars on the side of a gear box?
Thanks in advance.
Unread 12-02-2009, 20:32
EricH's Avatar
EricH EricH is offline
New year, new team
FRC #1197 (Torbots)
Re: Jaguar placement
There is no FRC rule about placement...
...but there is also this little thing known as common sense. Why would you place a rather expensive electronic component right next to a bunch of rotating parts that could damage it? Personally, that's asking for trouble. Think of the possibilities...
--gear tooth snaps off and lands in the Jag.
--gearbox shakes under a sudden heavy load, shaking off the Jag.
--rotating shafts grind through the bottom casing of the Jag.
See what I'm getting at here?
Past teams:
2003-2007: FRC0330 BeachBots
2008: FRC1135 Shmoebotics
Unread 12-02-2009, 23:13
Steigerwald's Avatar
Steigerwald Steigerwald is offline
Questionable???
FRC #0115 (MVRT)
Team Role: Mechanical
Steigerwald is an unknown quantity at this point
Send a message via AIM to Steigerwald
I agree, you should keep the electronics and the wiring away from the moving parts. Last thing you want is a fire or burnt out component cause power wires get ought up in a chain and broken.
We have found Polycarbonate to be the best material for mounting electronics. It is very strong, clear, and available in all sizes.
MVRT - Monta Vista Robotics Team #115
2009 Robot El Toro 13
2009 Davis Sacramento Regional Finalist
2009 Davis Sacramento Regional Engineering Inspiration Award
2009 Davis Sacramento Regional Best Website Award
2008 Championship Best Website Award
2008 Davis Sacramento Regional Best Website Award
2008 San Jose Best Website Award
2007 Davis Sacramento Regional Best Website Award
2006 San Jose Best Website Award
Unread 13-02-2009, 07:59
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
Andre,
The Jaguar has a temperature probe built in that senses ambient temperature for the fan operation and failsafe for overall device operation. Since transmissions do get warm to hot from frictional forces, I would not recommend mounting the Jaguar close to the transmission. I also make the same recommendation for the PD. The circuit breakers are a temperature sensitive device. If the temperature is elevated, the trip point is adversely affected.
Al
WB9UVJ
www.wildstang.org
________________________
Jaguar CAD Patrickwhite Inventor 2 24-01-2009 14:07
Jaguar Failure Nightfall831 Electrical 8 21-01-2009 10:12
Jaguar Problem Sauce Electrical 7 10-01-2009 14:28
Jaguar deadband? skidmarks Motors 1 06-01-2009 22:53
Jaguar Failure Jon236 FRC Control System 21 23-12-2008 18:30
