Go to Post ...playing hard and impressing teams is way more valuable than trying to play god with the rankings. - JamesBrown [more]
Unread 12-02-2009, 21:25
dboisvert dboisvert is offline
AKA: Dan Boisvert
FRC #2405 (Divided by Zero)
dboisvert is an unknown quantity at this point
Micro Switch Code
Declared 2 Micro Switches
Code:
DigitalInput *flipperdoorright;
DigitalInput *flipperdoorleft;
Where I want the variables to get data from
Code:
flipperdoorleft = new DigitalInput(1);
flipperdoorright = new DigitalInput(2);
What I want it do with those variables
Code:
			if (m_leftStick->GetRawButton(5) == 1 && flipperdoorright == 1 ) {
				flipperdoor->Set(Relay::kForward);
				//delay(10);
			} else if (m_leftStick->GetRawButton(4) == 1 && flipperdoorleft == 1 ){
				flipperdoor->Set(Relay::kReverse);
				//delay(10);
			else{
				flipperdoor->Set(Relay::kOff);
(The Error shows up on the if and else if lines)
Error: ISO C++ forbids comparison between pointer and integer
I only included the lines giving me the errors and those that are relative to the question.
So what am I doing wrong?
Pressure Switch code kE7JLM Programming 3 25-01-2008 14:54
Need Help Wiring Micro Switch/Limiting Switch Windward Electrical 2 07-02-2006 18:26
Pressure switch code kingpin3787 General Forum 11 22-02-2004 21:52
HELP US PLEASE?!?!(pressure switch code) kingpin3787 General Forum 1 21-02-2004 15:13
sample limit switch code??? tml240 Programming 5 17-02-2004 17:13
