pic: Vex Caster
Re: pic: Vex Caster
We considered using a caster, but decided that after a series of sharp turns, or backwards and forwards movements, the wire could get wrapped around the caster and possibly pull out. Do you guys have a method to avoid this?
Re: pic: Vex Caster
Yeah we had an idea, as you can see the wire passes through the caster bearing's center, then the idea would have been to use a Slip ring like the ones discussed here, but for cost and time we were going to try a Phone cord untangler but this design was mothballed before we could try it.
| pic: Pic 2: "caster wheel" crab drive combo | adengler | Extra Discussion | 7 | 27-01-2009 21:14 |
| pic: Pic 1: "caster wheel" crab drive combo | adengler | Extra Discussion | 1 | 25-01-2009 17:44 |
| Caster questions? | team 2191 | Technical Discussion | 7 | 19-01-2008 15:16 |
| Caster Mechanism | mzitz2k | Technical Discussion | 11 | 01-01-2004 17:01 |
| Caster Modification | archiver | 2001 | 1 | 23-06-2002 22:58 |
