Go to Post A good thing to do when thinking about designs like this, ask yourself "what do I gain?" - lemiant [more]
View Poll Results: What's your team doing for Traction Control?
Joystick Ramp-Up 15 31.91%
Sensor-based TC (encoder, accelerometer, etc...) 20 42.55%
All driver skill, baby! 7 14.89%
Other! (Please elaborate =] ) 5 10.64%
Voters: 47. You may not vote on this poll
Unread 13-02-2009, 04:04
Zorkinian Zorkinian is offline
AKA: John Gilbert
FRC #0488 (Xbot)
Zorkinian is on a distinguished road
Traction Control Poll
Hey all,
I'm wondering what teams are doing with traction control these days, especially given all the threads on it currently. What's your team doing?
We're going with a system of drive and follow encoders to detect slippage, and react appropriately.
Unread 13-02-2009, 09:08
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: Traction Control Poll
poll only lets us pick one, but we're using different techniques in autonomous and teleoperated....
Unread 13-02-2009, 09:29
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Rookie Year: 1999
Tom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond repute
1. Formula that calculates maximum pwm that can be applied at any given speed (experimentally determine formula).
2. Then an Idler wheel that measures slip percentage and reduces pwm values to match current speed if slip exceeds threshold (if your robot gets knocked sideways suddenly, you're going to start spinning the wheels and you need to slow them back down to reattach).
Unread 13-02-2009, 10:18
Stuart's Avatar
Stuart Stuart is offline
#include coffee.h
FRC #1745 (P51- Mustangs)
Stuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond repute
Send a message via AIM to Stuart
you know when we had a practice field last week. we noticed that traction control on a 4 wheel drive robot is only important for like the first half second of a match . . we found that Momentum control is a much more desirable thing( don't fight the trailer use the trailer to your advantage).
Proud mentor of Team #1745 the P-51 Mustangs
If at first it doesn't work, use a hammer.
If that doesn't work, use a bigger hammer.
Unread 13-02-2009, 10:24
FRC4ME FRC4ME is offline
FRC #0339
Rookie Year: 2007
FRC4ME has a brilliant futureFRC4ME has a brilliant futureFRC4ME has a brilliant futureFRC4ME has a brilliant futureFRC4ME has a brilliant futureFRC4ME has a brilliant futureFRC4ME has a brilliant futureFRC4ME has a brilliant futureFRC4ME has a brilliant futureFRC4ME has a brilliant futureFRC4ME has a brilliant future
Well, right now we're testing two different systems. One ramps up the joystick values over time and must be manually tuned. The other does some math to calculate the maximum PWM value we can apply to a motor at any given time based on the RPM of the motor (measured with encoders), coefficient of friction, weight of robot, battery voltage, and published CIM specifications. The advantage here is that there are no constants to tune - provided your measurements are correct, the system is guaranteed to produce the most responsive robot possible as per the laws of Newtonian physics.
Unread 13-02-2009, 11:06
Andrew Y.'s Avatar
Andrew Y. Andrew Y. is offline
FunYun
AKA: Andrew Yun
FRC #2415
Andrew Y. has much to be proud ofAndrew Y. has much to be proud ofAndrew Y. has much to be proud ofAndrew Y. has much to be proud ofAndrew Y. has much to be proud ofAndrew Y. has much to be proud ofAndrew Y. has much to be proud ofAndrew Y. has much to be proud ofAndrew Y. has much to be proud of
traction controle...PSHH we dont need to stinking traction controle...all in the wrists
2809 - Traction Control Demo Mentor_Mike Robot Showcase 34 17-02-2009 18:52
Implementation of Traction Control keehun Programming 5 10-02-2009 10:02
PID traction Control dpeterson3 C/C++ 5 26-01-2009 21:11
Is it worth it to implement traction control? dmlawrence Rules/Strategy 5 05-01-2009 21:28
Traction Control Algorithm Mr. Lim Programming 3 20-01-2004 14:26
