Go to Post Just fill your wheels with depleted uranium - EmileH [more]
Unread 13-02-2009, 06:48
dadamson's Avatar
dadamson dadamson is offline
FRC #2546
dadamson is an unknown quantity at this point
I/O Problem When Downloading To Robot
So we're trying to download a simple robot program to the cRIO, and are met with the error message "IO problem while downloading to robot" (I don't have the screen in front of me, but that's more or less it).
Here's the history:
I installed the WindRiver and DS updates, but did not update the cRIO image to v11. I was able to connect to the cRIO and download code, but it threw an exception at the start of the debug session because (I assume) the libraries didn't match.
I beat my head against that wall for a while, until I realized I had neglected the image update. After flashing the cRIO to v11, I am still able to ping the cRIO, I can establish a remote connection in WindRiver (and MAX), but I can't download anything to the robot - WindRiver reports an "IO problem while downloading to robot".
Help or insight would be greatly appreciated.
Proclamations of doom will be heard, but they shall be overcome.
EasyC Downloading Problem Jimmy_Team7011 Programming 1 15-11-2007 10:21
Problem downloading code Romeo1351 FIRST Tech Challenge 6 01-12-2006 06:33
Beginner problem with downloading pagemauck Programming 2 17-01-2004 13:24
serious problem found - robot controller resets when jarred! KenWittlief Electrical 23 19-03-2003 13:30
Downloading Problem to EDU Motherboard Jankenpoe Programming 0 16-02-2003 14:29
