Go to Post I am a mechanical engineer. I have known since I was about 12 that I wanted to make complicated mechanisms. - Paul Copioli [more]
Unread 13-02-2009, 11:18
mgurgol mgurgol is offline
FRC #1094
mgurgol is just really nicemgurgol is just really nicemgurgol is just really nicemgurgol is just really nicemgurgol is just really nice
At Competition, can robot run from PC
Our team has been having problems lately with not being able to deploy code to the robot. We are working to correct the issue, but I was wondering...
I beleive it is allowed to have a laptop connected during the competition, you can't use it for the camera because of the bandwith, but would you be able to run the robot code through the laptop for the competition, which would eliminate the need for deploying to the robot. The robots will be powered and connected (and disabled) prior to the match, so once the robot is up, the run button could be pressed and the code downloaded to the cRio.
Just an option if there are issues with the deploy. I know from the ni boards that there has been an issue with the Signal Processing vi's and deploying.
can we run our pnuematics to a spike? Alex_2487 Pneumatics 2 11-02-2009 21:09
Can I run the code on a computer? Anton Programming 1 06-02-2005 05:24
Can an a robot take a tetra from another robot in their allinace? Koko Ed Rules/Strategy 3 10-01-2005 23:01
Can you run a Window Motor on a victor Noah Melamed Electrical 1 07-02-2004 16:11
