Go to Post Temp wiring is always bad but it is made worse when dealing with a $1000 part. You wouldn't try to lash a makeshift power source to your PC. - Al Skierkiewicz [more]
Unread 13-02-2009, 12:34
Kruuzr Kruuzr is offline
Mentor - electrical, software
AKA: Steve Cote
FRC #1922 (Ozram)
Kruuzr has a spectacular aura aboutKruuzr has a spectacular aura about
pic: Ozram 1922 Toto
Unread 13-02-2009, 12:35
James Tonthat James Tonthat is offline
FRC #0148 (Robowranglers)
James Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond repute
Re: pic: Ozram 1922 Toto
Pretty spiffy design.
Was there any reason you didn't use a smaller diameter piston?
Can't wait to see the polished version, good work!
James Tonthat
Mechanical Engineer, RackSolutions, a subsidiary of Innovation First International
Lead Engineer - Texas Torque - 2009-2014
Mentor - Robowranglers - 2015-
Unread 13-02-2009, 12:38
Elgin Clock's Avatar
Elgin Clock Elgin Clock is offline
updates this status less than FB!
AKA: the one who "will break into your thoughts..."
FRC #0237 (Black Magic)
Elgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond reputeElgin Clock has a reputation beyond repute
Send a message via AIM to Elgin Clock
Wow, that looks very overweight!
What is the weight on that as of when that picture was taken out of curiosity?
The influence of many leads to the individuality of one. - E.C.C. (That's me!!)
Unread 13-02-2009, 14:10
AKA: Steve Cote
FRC #1922 (Ozram)
We used that piston to get the maximum distance shot, about 9-10 feet. We shoot lesser distances by limiting the length of the pulse sent to the pneumatic valves. Our camera system can only track to about the same distance.
As to the weight, the last time we weighed it (with a very accurate scale) we were about 2 pounds overweight. There will probably be a few more holes in the final product.
Steve
Unread 13-02-2009, 16:52
Daniel_LaFleur's Avatar
Daniel_LaFleur Daniel_LaFleur is offline
Mad Scientist
AKA: Me
FRC #2040 (DERT)
Daniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond reputeDaniel_LaFleur has a reputation beyond repute
Send a message via MSN to Daniel_LaFleur
Very nice.
Are y'all going to be at BAE? I look forward to seeing it in action.
___________________
"We are not now that strength which in old days moved earth and heaven; that which we are, we are;
One equal temper of heroic hearts, Made weak by time and fate, but strong in will
To strive, to seek, to find, and not to yield. "
- Tennyson, Ulysses
Unread 13-02-2009, 21:05
FlyingHerring's Avatar
FlyingHerring FlyingHerring is offline
CAD-Boy
AKA: Carson
FLL #1388 (Eagle Robotics)
Team Role: CAD
Rookie Year: 2007
FlyingHerring is an unknown quantity at this point
Can you aim that thing? We briefly considered using a piston to shoot, but the software guys said it would be impossible to aim, you guys must have some pretty good programmers or an exceptional driver. Well, whichever it is, good luck.
Off of the Indpendent, March 21 2008:
http://www.independent.ie/world-news...t-1324228.html
Unread 14-02-2009, 00:09
Ian Curtis Ian Curtis is offline
Best Available Data
FRC #1778 (Chill Out!)
Ian Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond repute
Nice!
How much time do you need to reload?
Also, what's the projection to the left? Can you dump out one side and shoot out the other? Or is that just a holder for an empty cell?
See you at BAE!
CHILL OUT! | Aero Stability & Control Engineer
Adam Savage's Obsessions (TED Talk) (Part 2)
It is much easier to call someone else a genius than admit to yourself that you are lazy. - Dave Gingery
Unread 14-02-2009, 00:30
Smoores's Avatar
Smoores Smoores is offline
AKA: Steve Moore
FRC #2272 (Metalheads)
Team Role: Student
Rookie Year: 2007
Smoores will become famous soon enoughSmoores will become famous soon enough
finally I've found another team that also only uses 2 belts for the lift. My team's design is very similar, except we use a pulley, belts for the cannon. We get about 15 ft.
Aviation in itself is not inherently dangerous. But to an even greater degree than the sea, it is terribly unforgiving of any carelessness, incapacity or neglect.
2007 Championship Highest Rookie Seed - Galileo
2007 CA Rookie All-Star
2007 CA Highest Rookie Seed
Unread 14-02-2009, 09:03
AKA: Steve Cote
FRC #1922 (Ozram)
The turret spins roughly 270 degrees and it autotracks using the camera. Currently, it does a great job with still / slow moving targets. We're going to try some tricks to get it to 'lead' faster moving targets. We'll see by Monday
Steve C
Unread 14-02-2009, 09:08
AKA: Steve Cote
FRC #1922 (Ozram)
Originally Posted by iCurtis View Post
Nice!
See you at BAE!
It takes about 2-3 seconds to reload. That projection on the left is a pneumatic cylinder that has a large 'paint can' looking plunger that pushes the ball off the stack and onto the basket. The loading elevator can hold 6-7 orbit balls.
