Driver Station firmware revison
The last Team update #12 calls for updating the driver station. Has anyone done this yet?
The new image is called dsud_pkg(1).bin. Should I rename this to dsud_pkg.bin? Thank you |
Re: Driver Station firmware revison
You will need to rename the file for the update to complete properly. The driver station looks for that specific file name when the update process is started, and if it does not find it, it assumes that the update process was started unintentionally, and will not proceed any further with trying to update...
My team updated the driver station. It works fine. Just follow their steps on on the FIRST FRC Control System page where you get the firmware from.
| driver station firmware update | bobbyt14 | Programming | 15 | 14-02-2009 15:05 |
| Driver Station Firmware Update 2009-01-22c1 | Mark McLeod | FRC Control System | 4 | 09-02-2009 11:52 |
| driver station and cRIO firmware update help | asianfez123 | FRC Control System | 1 | 16-01-2009 02:34 |
| Driver Station firmware update failure | ofshea | FRC Control System | 8 | 13-01-2009 11:35 |
| Help with updating firmware on Driver Station | urg8rb8 | FRC Control System | 3 | 28-12-2008 02:53 |
